Replacing suspension arms: Bushing Preload? How to fix?
Old Jul 13, 2003 | 04:46 PM
.jacob's Avatar
Default Replacing suspension arms: Bushing Preload? How to fix?
I am doing an ITR 5 lug conversion. I sucessfully got the rear trailing arm onto the car (ver easy) and got all ready to go for the wheel. All of the arms have OEM bushings and I think that a lot of them got preloaded from the install. Example being I'd get one bolt around a bushing all tightened down and then kinda have to muscle the arm into position to do the next bolt putting load on the bushing. I think pretty much all of the bushings have load on them. Anyone know how I could fix them, taking all the load off but still of course having the arm on and all? My thoughts were too loosen all of the bolts but not take them out completely and then retighted.
-Jake
Old Jul 13, 2003 | 06:39 PM
Mohudsolo's Avatar
Default Re: Replacing suspension arms: Bushing Preload? How to fix? (Ninety2SiR)
The maual recommends tightening the bolts with the car sitting at normal ride height with load. I don't have a big hole under my car so I put a jack under the outer part of the suspension and lift enough to load it while keeping a jackstand under the car just in case. Then tighten everything to the torque spec.
Old Jul 14, 2003 | 05:53 AM
.jacob's Avatar
Default Re: Replacing suspension arms: Bushing Preload? How to fix? (Mohudsolo)
So like put the whole car on jackstads to get more access. Then use the jack to lift the wheel to the desired height, then loosen all the nuts and tighten? Thats all?
-Jake
Old Jul 21, 2003 | 08:44 PM
mingchi69's Avatar
I to Smooch Pickle
you dont need to put the wheel.. just jack up the lower control arm.. to ride height..
Vagitarian
Feb 18, 2014 01:35 PM
bank2me
Aug 19, 2011 06:53 PM
se_hatchback
Jun 5, 2009 01:35 PM
dth0ng69
Suspension & Brakes
Nov 15, 2008 05:42 PM
jmai86
Jul 16, 2007 10:40 PM
