ctr cams in 01 b18c1 with jdm itr pistons??
Old Jul 13, 2003 | 04:41 PM
slogsr's Avatar
Default ctr cams in 01 b18c1 with jdm itr pistons??
would any one recomend the ctr intake and exhaust cams in my motor? I already purchased some jdm ITR pistons and i will have them installed the same as the cams. Juss wanted to know if the ctr cams would make a big difference.
thankx
Old Jul 13, 2003 | 04:44 PM
Tweakmeister's Avatar
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (slogsr)
yeah they will
Old Jul 13, 2003 | 04:56 PM
Rob Dizzle's Avatar
what year head are u using?
ctr cams will work nice with the mid 11 cr
dont rev higher than 8,000rpm if you are on stock gsr valvesrpings
Old Jul 13, 2003 | 05:15 PM
slogsr's Avatar
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (Bob-DC2)
They have the ctr valve springs with them, but is it still a problem? Im using a 01 Gsr b18c1, stock head and block. The jdm itr pistons are not in yet. But if memory serves it should have a 11.5:1 cr with the jdm itr pistons.
Old Jul 13, 2003 | 07:22 PM
Mr Hammond's Avatar
a/k/a Jomo
Great mid-range gains and over all. Nice value for the money.
Old Jul 13, 2003 | 10:08 PM
rodrez.'s Avatar
I was running a similar set up before, same as yours except I was using US ITR pistons. Great set up, made decent midrange as well as top end. I doubled up on the exhaust valve springs and took it to 8500
Old Oct 1, 2003 | 09:07 PM
dabomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slogsr &raquo;</TD></TR><TR><TD CLASS="quote">would any one recomend the ctr intake and exhaust cams in my motor? I already purchased some jdm ITR pistons and i will have them installed the same as the cams. Juss wanted to know if the ctr cams would make a big difference.
thankx</TD></TR></TABLE>
hey man did you ever end up doing this? i'm very curious cause i'm about to drop the same cams in my b18c1 w/jdm itr pistons. let me know thanks
Old Nov 14, 2003 | 06:13 PM
808State's Avatar
New User
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (dabomb)
my B18C1 setup has the spoon balanced jdm itr pistons with ctr cams. make sure you get the ctr valvetrain. love this setup. 14.3 passes with street tires in 96 civic coupe.
enjoy your upgrade.
Old Nov 15, 2003 | 03:56 PM
SickBastard's Avatar
I want that setup in my car. Just dont know if I should go with ITR pistons or PR3's?
Old Nov 19, 2003 | 06:10 AM
bulori's Avatar
Default Re: (SickBastard)
hi i also have a gsr engine, but i will get the PR3 pistons (b16a2) but i have a question about cams
TODA vs CTR, wich one its better??all around
Old Nov 19, 2003 | 06:14 AM
CTR94Joes's Avatar
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (808State)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808State &raquo;</TD></TR><TR><TD CLASS="quote">my B18C1 setup has the spoon balanced jdm itr pistons with ctr cams. make sure you get the ctr valvetrain. love this setup. 14.3 passes with street tires in 96 civic coupe.
enjoy your upgrade.</TD></TR></TABLE>
Hey me to but i never ran it on the track. Still trying to sell the car.....
But it's a big bang for your bucks. You should change the intake manifold to SK2 while your at it...
Old Nov 19, 2003 | 10:37 AM
eyeamvic's Avatar
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (CTR94Joes)
With the CTR cams I'd recommend the jdm p73's with a 2 or 3 layer headgasket. I heard the pr3's won't fit on the b18c1/5 pistons. You have to rig the rods for the b16a/b17a/b18b to fit b18c1/c5 pistons, I don't see why it wouldn't be the same vice versa.
Old Nov 24, 2003 | 11:29 PM
808State's Avatar
New User
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (eyeamvic)
definitely go with a jdm p73 ecu. stock gsr obd2 ecu is not as responsive.
Old Nov 25, 2003 | 04:51 AM
bulori's Avatar
i read that the pr3 can be install in a b18c
just have to work the piston a bit
Old Dec 7, 2003 | 08:58 PM
LHC's Avatar
LHC
Default Re: ctr cams in 01 b18c1 with jdm itr pistons?? (bulori)
im also running the jdm itr o/s pistons my c/r set at 11.8. CTR cams is wot i want but not sure if c/r is too high for the cams...any input?
92integraVTECgsr
Nov 18, 2007 02:51 PM
Dominicandude
10
Jan 21, 2004 07:09 PM
NA-C5
15
Dec 12, 2003 07:48 PM
daewonder.
14
Nov 15, 2003 01:17 PM
Justin95GSR
Apr 14, 2003 04:54 AM
