HID users, where did you mount everything.
Old Jul 13, 2003 | 04:21 PM
Aaron M's Avatar
Default HID users, where did you mount everything.
I'm debating wether or not to re-mount all my equipment behind the bumper. Here is were everything is right now
Passenger side install
Drivers side install
Where did you guys mount your stuff? Post your pics.
Old Jul 13, 2003 | 04:57 PM
MTK Kommander's Avatar
Default Re: HID users, where did you mount everything. (SilverB18C1)
i would do mine behind the bumper if i wanted everything to look clean and OEM.. thats a good idea
Old Jul 13, 2003 | 07:14 PM
T.J.'s Avatar
ive got a set of tl hid i mounted the ballace bhind the sed of the bumper looks stock and realy good to
Old Jul 13, 2003 | 08:00 PM
Default Re: HID users, where did you mount everything. (Skunk2whore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2whore &raquo;</TD></TR><TR><TD CLASS="quote">ive got a set of tl hid i mounted the ballace bhind the sed of the bumper looks stock and realy good to </TD></TR></TABLE>
Old Jul 13, 2003 | 08:02 PM
NrG's Avatar
NrG
say what?¿
Old Jul 13, 2003 | 09:36 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm debating wether or not to re-mount all my equipment behind the bumper. Here is were everything is right now
Well I've got the Phillips ballasts w/ integrated ignitor, so that right there makes my setup a bit cleaner than Catz. However mine has the OEM-style D2S connector coming off the ballast, which is too big to fit through the holes in the frame rails, and I can't extend the wires because the bulb has to be within a certain distance of the ignitor (which of course is inside the ballast).
Old Jul 13, 2003 | 10:50 PM
Aaron M's Avatar
tell me about it, the catz kit is nothing but wires. but if i mounted everything away and got about 600feet of wire loom it should look pretty stealthy
Old Jul 13, 2003 | 10:54 PM
Community Builder
Default Re: (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">tell me about it, the catz kit is nothing but wires. but if i mounted everything away and got about 600feet of wire loom it should look pretty stealthy</TD></TR></TABLE>
Just remember, don't extend any of the wires between the ignitor and the bulb or you'll be asking for trouble. You can however mount the ballast and ignitor as far apart as you want to.
Old Jul 14, 2003 | 10:19 AM
ebelp's Avatar
Default Re: (PatrickGSR94)
I think the way you have it looks good. Can you post an entire engine bay pic or resize those? (way too big!)
I still don't know how you Catz owners put up with all that wiring. Thank god for Trevor and his old Philips kits.
Old Jul 14, 2003 | 10:29 AM
Aaron M's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">I still don't know how you Catz owners put up with all that wiring.</TD></TR></TABLE>
100 pack of zip ties from home depot is your friend
ill take a full bay shot tonight
Old Jul 14, 2003 | 10:37 AM
ebelp's Avatar
Here's mine (just to make you jealous ):
4 zipties total...(all the wiring is seen here)
0 zipties on driver's side...
Old Jul 14, 2003 | 11:25 AM
Aaron M's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Here's mine (just to make you jealous ):
you win
the main reason i want to mount under the bumper is because im affriad that water will hit the drivers side ballast.
Old Jul 14, 2003 | 11:28 AM
skafia's Avatar
25 Year Member
For the left ballast I mounted it under the ABS bracketk, and the right ballast is wedged in the hole where the windshield reservoir is (but that requires power steering to be removed).
My ballasts also look smaller than yours.
Old Jul 14, 2003 | 01:40 PM
Calavera's Avatar
Default Re: (skafia)
shouldnt the ballasts be water proof though?
Old Jul 14, 2003 | 02:39 PM
Aaron M's Avatar
Default Re: (Calavera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt the ballasts be water proof though?</TD></TR></TABLE>
yea, but if i can help it, id like it to be out of the way of direct water.
Old Jul 14, 2003 | 03:42 PM
EL'ation's Avatar
Left one is drilled and right one is held by couple of cable ties under the cruise control. Does anyone else have cruise like mine?
Old Jul 14, 2003 | 09:52 PM
Aaron M's Avatar
Default Re: (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Can you post an entire engine bay pic or resize those? (way too big!)</TD></TR></TABLE>
Old Jul 15, 2003 | 04:04 AM
ebelp's Avatar
Wow, your install looks A+ to me. I wouldn't change a thing.
btw, damn you and your spotless engine bay!
Old Jul 15, 2003 | 04:59 AM
OneThirtyEight's Avatar
wow! that is the CLEANEST engine bay I have ever seen.
Old Jul 20, 2003 | 05:29 PM
95TEG's Avatar
Default Re: (97blackteg)
Bump, any other input?
Old Jul 20, 2003 | 08:32 PM
c1hatch's Avatar
looks 10x better than mine, mines zip-tied to what ever is there(once again, zip-ties save the day)
IntegraUC
Jan 6, 2009 09:18 PM
lx sky
Honda Civic (2006 - 2015)
Jul 12, 2007 12:33 PM
BoOsTiN Dc2
Nov 8, 2005 08:49 PM
MaskedAP1
Nov 10, 2004 12:17 PM
gsr-2nr
Mar 24, 2003 12:12 AM
