How do I move my battery out of the engine bay?
try searching, its been covered many times
just so this post is helpful tho, heres a write-up by fourthgenhatch
http://www.fourthgenhatch.com/index2.html
then click on techincal, then how to, and click on: <moving battery to trunk>
and also homemadeturbo.com
http://www.homemadeturbo.com/t....html
I bought a whole battery relocation kit from Summit for $50. It includes everything you need (with instructions). Good deal
50???
ok look for $5 go buy a marine battery box in walmart
for $20 got to a car system shop and get however much feet of 4gauge wire u need...just run a wire from where the positive line is under the hood( so basiclaly u got a battery clamp just laying there and put the 4g wire in it and tape it all around with electrical tape. then just run it to the ttrunk and get a ground for back there(where the spare tire goes it easiet) . but REMBER leave the ground to the tranny just put that on anythign metal so it wil still run. hope it was helpful
Yeah when I removed my stock negative bat cable it took away the ground essentially. It made by starter blow up and burned up part of my cluster. I guess the power had no where to go so it started blowing up things.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durrett syndrome »</TD></TR><TR><TD CLASS="quote">50???
for $20 got to a car system shop and get however much feet of 4gauge wire u need...just run a wire from where the positive line is under the hood( so basiclaly u got a battery clamp just laying there and put the 4g wire in it and tape it all around with electrical tape. then just run it to the ttrunk and get a ground for back there(where the spare tire goes it easiet) . but REMBER leave the ground to the tranny just put that on anythign metal so it wil still run. hope it was helpful</TD></TR></TABLE>
Parts List
Battery Box
$15.00
17Ft 1 0/T Wire
$22.00
2 Battery Terminals
$3.00
Distribution Block
$10.00
Misc Connectors
$3.00
Group 24 Battery
$39.00
Ground Wires
Free (est. $10 - $15)
Total
$92.00
Summit is cheaper than HomeMadeTurbo's job.
Parts List
Battery Box
$15.00
17Ft 1 0/T Wire
$22.00
2 Battery Terminals
$3.00
Distribution Block
$10.00
Misc Connectors
$3.00
Group 24 Battery
$39.00
Ground Wires
Total
$92.00
You have a good spot to hook up the ground, cause my radio gets bad signal and i'm pretty sure its cause i have bad ground... just my guess.
