How to clear DOHC ZC with factory crx hood.
Old Jul 13, 2003 | 02:01 PM
t0eKnEe's Avatar
Default How to clear DOHC ZC with factory crx hood.
I'll sum it up with pics... too lazy to type.
Here you can see how high the motor sits.
Just get a dremel and cut away.
I used a small bit so it would be less of a chance to cut thru the hood.
Here is all you have to cut.
I ran without a timing belt cover too, but the hell with that. I hope this helps..
Old Jul 13, 2003 | 02:10 PM
Malgerus's Avatar
Default Re: How to clear DOHC ZC with factory crx hood. (t0eKnEe)
Good post!
But, rather than cutting crap, how about shimming the driver's side engine mount down with washers, or shimming the hood UP with washer underneath the bolts that support the hood?
EDIT: didn't see the topic two topics down
Old Jul 13, 2003 | 04:00 PM
JackAcc's Avatar
Default Re: How to clear DOHC ZC with factory crx hood. (Mr. S)
Thanks! I had a question about this yesterday. That seems to be the easiest solution to this problem. Thanks for the pix!
Old Jul 13, 2003 | 07:11 PM
DJ_SaNdOz's Avatar
Default Re: How to clear DOHC ZC with factory crx hood. (JackAcc)
**** that- just put washers in the drivers side mount & use a longer bolt. I just did my ZC swap about 1 month ago, and I'm glad that I used the washers, why cut into a perfectly good hood?
Old Jul 13, 2003 | 08:10 PM
t0eKnEe's Avatar
Default Re: How to clear DOHC ZC with factory crx hood. (DJ_SaNdOz)
whatever floats your boat. Everybody has their own way
Old Jul 13, 2003 | 09:01 PM
c8r9x's Avatar
i put a b16 in my crx and for like 2 weeks the hood wouldnt close right without it hitting the motor but the one day i let the hood go to close it and it closed right and it doesnt look crooked or anything....
Old Jul 14, 2003 | 01:43 PM
CRXRageD's Avatar
I just pounded the skeleton with a hammer where the timing belt was close to rubbing the hood. It doesn't rub anymore.
Old Nov 15, 2003 | 08:06 AM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Good post!
I wouldn't recommend it. That changes your axle angle and when you start making any kind of power you'll have axle issues on that side.
Old Nov 15, 2003 | 08:40 AM
virginia_dude's Avatar
EDIT: didn't see the topic two topics down </TD></TR></TABLE>
thats exactly what I did, easy cheap and it works.
Old Nov 15, 2003 | 08:41 AM
Default Re: How to clear DOHC ZC with factory crx hood. (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't recommend it. That changes your axle angle and when you start making any kind of power you'll have axle issues on that side.</TD></TR></TABLE>
I have been running and running hard exactly like this for 2 years with NO problems with my axels of any sort. And I have CAI, header, 2.5 catback and it runs like a strapped ape. You are shimming 1/4 inch for clearance not 4 inches.
Old Nov 16, 2003 | 08:26 AM
1990hondaHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JackAcc &raquo;</TD></TR><TR><TD CLASS="quote"> That seems to be the easiest solution to this problem. </TD></TR></TABLE>
All you need to do is to put a few washers on the driver's side mount. That IS the easiest way to solve that problem. Or if you want to go for a more Euro look, get a ZC hood. It has the bump so the cover will clear and not rub the underside of the hood.
spikehead221
Apr 2, 2008 12:05 PM
drewboy
13
Jan 11, 2006 01:56 PM
crxzcracer
Apr 1, 2004 02:05 PM
importboi22
10
Jan 2, 2004 05:26 PM
l0p3z
Sep 23, 2001 10:15 PM
