Need help with EF coupe! How do I check codes?
Old Jul 13, 2003 | 12:28 PM
T-sohctec's Avatar
Default Need help with EF coupe! How do I check codes?
I'm trying to trouble shoot my friends car, it's a EF(89') coupe auto LX.
I can't find the jumper to check the engine codes.
My main question is, where is the jumper or how do I check obd0 codes?
thanx to anyone who can help.
If your still reading this post and you are this bored here is the problem.
Car starts sometimes, sometimes it will not.
We are not getting any spark off of the plug wires. We have just changed the distributor with a brand new rOEM unit. We did however get spark off of the coil but we haven't checked to see if the new unit is sparking. We will be checking that after lunch. any help is appreciated.
Old Jul 13, 2003 | 12:31 PM
RHD_BB4T's Avatar
Default Re: Need help with EF coupe! How do I check codes? (T-sohctec)
The ECU has a little red LED that flashes in "code" to let you know what code it is throwing. It's located under the carped on the passenger footwell. When you turn the key to the ON position, the ECU will flash the code (s).
HTH
Dan P.
Old Jul 13, 2003 | 12:34 PM
T-sohctec's Avatar
Default Re: Need help with EF coupe! How do I check codes? (Dan_P)
Thanx, mang!
saunders400
Aug 13, 2007 09:13 AM
efb20vtec
Feb 15, 2007 01:07 PM
crazi92hb
Nov 22, 2006 05:20 PM
downivlife
Aug 13, 2004 06:31 AM
D16OnTop
21
Dec 15, 2003 10:44 AM
