i need help with JDM headlights and cluster install
What do you need to know?
I recently did a complete front and rear end conversion.
The only difference is that the JDM lights use 3 wires (single bulb) vs 4 wires
(2 bulbs).
So what you do is wire your US high beam wire, low beam wire and a ground to the
matching JDM wires. The 4th wires just cap off as you will not need this anymore.
Be warned!!! The JDM headlights SUCK for light output!!! I had to order a set of
JDM Raybrig Hyperwhites, and even then they are so-so. Eventually I will upgrade
to HIDs.
(2 bulbs).
to HIDs.
oneoffaccord
Jul 27, 2006 05:47 PM
dingusjt
Jun 9, 2004 04:55 PM
