ECU throwing a code 17, WTF!
Old Jul 13, 2003 | 08:53 AM
5DegAdv's Avatar
Default ECU throwing a code 17, WTF!
just wondering if someone could help me out a little bit?
Just put a new battery in, at the big K parking lot and I was getting it on the way home. I was doing about 80 in 3rd and hit a bump when my speedometer fell to 0. 10 seconds later the check engine light came on. When I got home I checked my ECU, got the 17 flashes. My manual say's it's the speed sensor and for help it said to take it to the dealership. Now I know i'm not going to do that, so maybe you guy's can help me out...This just happened so my motor was still hot but it looks like my cable is still in tacked with the trans. Could it be a fuse? a relay?
Thanx
Old Jul 13, 2003 | 11:04 AM
USDM 4G VTEC's Avatar
Default Re: ECU throwing a code 17, WTF! (jfoxmatt71)
that bump may have loosen ur speedo cable
go look under the intake manifold..... on the tranny...
u will see this cable that comes from the firewall to the tranny....
make sure its in and tight.... also make sure u didnt loose the lil pin that holds it....
after making sure its in., reset ecu by removing the hazard fuse for 15 sec and u good to go , if the cable goes back into place
Old Jul 13, 2003 | 11:21 AM
blackc's Avatar
Default Re: ECU throwing a code 17, WTF! (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">that bump may have loosen ur speedo cable
after making sure its in., reset ecu by removing the hazard fuse for 15 sec and u good to go , if the cable goes back into place</TD></TR></TABLE>
Old Jul 13, 2003 | 11:53 AM
blah13's Avatar
Default Re: ECU throwing a code 17, WTF! (dldom)
Also if that doesnt fix it pull the panel off that covers the back of your gauge cluster and check that the other end of the cable going into your speedo is plugged in tight.
aaronhume
Nov 21, 2006 12:00 PM
EF9 JAMS!!!
Mar 25, 2006 08:35 PM
dirtracer
Feb 9, 2005 06:36 AM
kim_2_da_chee
Dec 21, 2003 07:19 PM
rasta420
Jul 7, 2002 07:50 PM
