Pictures of Skunk 2 manifold install on GSR
Does anybody have any step by step pictures to go along with the instructions. I was trying to see the jdmhondaparts instructions but they took the page down, then I tried to see some pics inthe archives but they are down also.
I'd be interested in some pictures tooo especially since jdmhondaparts.com took town their tech page on how to install the skunk2 intake manifold....
c-speedracing.com has instructions w/ pix on how to remove the manifold..
http://www.c-speedracing.com/howto/jrsc/jrsc.php
even if someone posts pics, im not sure if i would recomend doing it.
it is all bolt on stuff, but you have to have some common sense of how the intake manifold is setup.
i can give u some more details if needed.
u will also need to buy some more acura parts to get it working properly without gehto fabbing you gsr stuff to make it work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 »</TD></TR><TR><TD CLASS="quote">even if someone posts pics, im not sure if i would recomend doing it.
u will also need to buy some more acura parts to get it working properly without gehto fabbing you gsr stuff to make it work. </TD></TR></TABLE>
I just wanted to see pictures because alot of stuff has to be changed when installing it. I already have all the extra parts needed to install the manifold, i just want some pictures so I could reference as I go along, since the manifold comes with no instructions.
list the parts that u have.
u need to change a few things
-extend/shorten some vaccuum lines
-change grommets on crank case breather box
T. a vac line as well
These are the parts I have so far
ITR Throttle cable
ITR Thottle cable bracket
Throttle body gasket
Intake manifold gasket
I did not know about T'ing the vacum line and changing the groments on the breather box. I also know i need a throttle pulley from a non-gsr, but i need to just go to the junk yard for that.
ITR Throttle cable
