creaking noise coming from back hatchback
Old Jul 12, 2003 | 09:27 PM
thatboi's Avatar
Default creaking noise coming from back hatchback
does anyone know how to get rid of the creaking noise from the hatchback area, it only does it at slow speeds, any suggestions will help
Old Jul 12, 2003 | 10:02 PM
..::91TEG-G2::..'s Avatar
Default Re: creaking noise coming from back hatchback (thatboi)
you could try putting shims between the two rubber halves of the trailing-arm bushings... that should stop the creaking noise
Old Jul 13, 2003 | 11:35 AM
rubens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatboi &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know how to get rid of the creaking noise from the hatchback area, it only does it at slow speeds, any suggestions will help </TD></TR></TABLE>
Electrical tape wrapped around the |_| the latch type thing will more than likely stop the noise.
Old Jul 13, 2003 | 12:38 PM
.RJ's Avatar
.RJ
Default Re: creaking noise coming from back hatchback (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">you could try putting shims between the two rubber halves of the trailing-arm bushings... that should stop the creaking noise </TD></TR></TABLE>
Uh... thats retarded. The trailing arm bushins is not in two pieces (hence halves) and putting shims there wont fix any creaking.
There are two rubber plug looking thingys on either side of the hatch - try turning them (try both directions) to seat the hatch against the body better. Will take some trial and error.
RJ
De_tour
12
Aug 3, 2007 05:55 PM
mportracer33
Honda S2000
Apr 6, 2007 10:11 AM
jesseb01x
Honda S2000
Nov 19, 2006 12:02 AM
HondaScott
Honda Civic (2001 - 2005)
Jun 13, 2006 04:05 AM
KRiS1
Sep 2, 2003 04:09 PM
