tail lights on ?
Old Jul 12, 2003 | 04:08 PM
slickrc's Avatar
Default tail lights on ?
whats wrong with my tail lights. the car is off and the lights are on. i disconnected the battery, and of course everything is off. when i reconnect, the light switch is on the off position but the tail lights stay on. y is this............
Old Jul 12, 2003 | 04:18 PM
RotaryBzzzz's Avatar
Default Re: tail lights on ? (slickrc)
does your horn work?
Old Jul 12, 2003 | 10:38 PM
Shtryfe's Avatar
Is it the tail lights or the brake lights, if its the brake lights it might be your brake light switch is stuck since you can turn them on by applying the brakes even if your car is off. Cheap part if thats the problem.
Old Jul 13, 2003 | 04:28 PM
bill-71SS's Avatar
look under at the brake pedal where the switch hits and make sure the stop button is there. very common for them to break off after a few years.
Old Jul 14, 2003 | 11:55 AM
slickrc's Avatar
yo, thanks for your help guys....i finally found the problem. there s is a rubber (triagunlar) piece that goes on the brake pedal which makes contact with the switch when the pedal is released. the rubber piece broke and it wasnt making any contact.....i found the piece at the dealer for $4.........gasp!
bill...u saved the day.....not to mention my money
Modified by slickrc at 9:07 PM 7/14/2003
Modified by slickrc at 9:11 PM 7/14/2003
barely4dr
26
Aug 28, 2016 04:52 AM
Jonathang
Oct 10, 2014 03:50 PM
jspinn13
May 6, 2012 08:12 AM
delsizzle1
Mar 22, 2012 10:27 PM
DC206R
May 1, 2009 04:39 PM
