weird sensors on LS motor swapping in DX Hatch..........?
Old Jul 12, 2003 | 03:48 PM
CRXBart's Avatar
Default weird sensors on LS motor swapping in DX Hatch..........?
Ok I'm doing a swap in a friend's car for him. He has a '90 TEG auto motor, it has a weird looking thing bolted to the intake manifold behind the dizzy, and another strange sensor by the coolant and oil pressure sensors on the back of the motor. I've done many ZC and B16 swaps and never encountered these sensors. I did a swap in this car previously with a ZC it is a DX BTW, it has a HASport Harness for a ZC and has no plugs for either of these sensors. Can I just delete the sensors? Are they for an auto tranny? Oh yeah we are using a 5speed tranny and ECU.
Old Jul 12, 2003 | 07:10 PM
CRXBart's Avatar
Default Re: weird sensors on LS motor swapping in DX Hatch..........? (CRXBart)
bump
Old Jul 12, 2003 | 07:19 PM
FourthGenHatch's Avatar
Pictures are always a help.
Old Jul 12, 2003 | 11:41 PM
vhd's Avatar
vhd
the one on the intake manifold is the egr valve, which is on automatics only. it can be removed cause you guys will be using a manual ecu. the other sensor i do not know without a picture. the only sensors that i know of on the back of a obd integ block is the thermoswitch and oil pressure sending unit.
Old Jul 13, 2003 | 06:27 AM
CRXBart's Avatar
Default Re: weird sensors on LS motor swapping in DX Hatch..........? (vhd)
It is a green plug on the back to the left of the other two sensors. It kinda reminds me of a knock sensor on a B16, the knock sensor I beleive was mounted closer to the cylinder head.
Old Jul 13, 2003 | 07:10 AM
CRXBart's Avatar
http://www.c-speedracing.com/h...n.jpg
its the green plug to the left of the oil line. thanks guys
Old Jul 13, 2003 | 07:45 AM
Dancing is Forbidden's Avatar
hmm. i have that same plug.
Old Jul 13, 2003 | 08:19 AM
CRXBart's Avatar
Default Re: weird sensors on LS motor swapping in DX Hatch..........? (EF9_SiR)
that's cool and all but what is it for, and do I need it when putting this motor in? thanks in advance. All DX's, Si's, ZC's, and B16A1's I've done have never had this mystery sensor. I'm baffled.
Old Jul 13, 2003 | 07:16 PM
CRXBart's Avatar
bumpity bump
Old Jul 14, 2003 | 10:16 AM
4potnick's Avatar
Is that the plug for the fans? I know that on older ls blocks the switch for the fans is on the back of the block. Newwer ls's have the fan switch/plug next to the thermostat.
Old Jul 14, 2003 | 11:03 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: weird sensors on LS motor swapping in DX Hatch..........? (4potnick)
Thats the knock sensor man. Trust me....i have the same plug on mine. Good luck
Sean
Old Jul 14, 2003 | 12:56 PM
CRXBart's Avatar
Default Re: weird sensors on LS motor swapping in DX Hatch..........? (sCeRaXn)
ok is the knock sensor required on the old school obd0 teg ecu? or can Ijust delete it?
Old Jul 14, 2003 | 08:02 PM
CRXBart's Avatar
Wait a minute I thought the knock sensor was a single wire when I did my b16? Are you positive it is a knock sensor?
Old Jul 15, 2003 | 09:46 PM
TomO's Avatar
I just got done swapping a B18A1 into two different cars and I saw that same plug....It has something to do with the oil, as I took it out and it ran into the oil passages. It has no ill effects if it's not plugged in. I think it might be for an oil temp sensor, but I'm not sure. Might be something to think of if you want to install an aftermarket oil temp or pressure gauge.
JDMefHATCH7
Feb 7, 2010 08:44 PM
SHIFKU(EF9 HOPE FUL)
13
Sep 21, 2005 12:58 PM
DB'd
14
Nov 11, 2004 08:12 PM
Digitalcivic
13
Jan 1, 2003 11:13 AM
B16CivicHB
Jan 4, 2002 01:05 AM
