aftermarket seats w/ STOCK seat belts???
I'm thinking of purchasing some aftermarket seats but I want to keep using my stock seat belts. Can I just take off my stock rail and buckle and attach it to the aftermarket seats?
Ya you could do that. i did that with mine for awhile. i had corbeau forza's in my teg. however they barely fit cause the shoulder support area almost hit the door. also using the stock belts will over time rub into the material and look kinda bad. that happened to my driver's side one
scott
scott
You can do that as long as the new seats are not buckets. If they are, then the lap belt will not be close enough to your body and will not do its job in a wreck.
gmoore
gmoore
igo4bmx
Oct 14, 2003 06:34 PM
Type-ARR
Oct 30, 2001 07:30 PM
