FS or FT: F22 - Accord F22A6 Block and Head ĪPick UpĪ NY
Old Jul 12, 2003 | 08:24 AM
SPEracing's Avatar
Default FS or FT: F22 - Accord F22A6 Block and Head ĪPick UpĪ NY
Have a f22a6 from a 91-93? Accord EX.
The block is a complete block(cut timing belt). The engine was pulled from a hit accord. The head was taken off to replace a head with bent valves.
I have the head with bent valves for it also. Perfect for a rebuild.
Great motor to build up for a turbo or nitrous. Or to replace your bottom end if you bust a ringland, or anything else.
BTW on a side note. People say you can use a dsm exhaust manifold and turbo on the f22. I put a 4g63 gasket on it and the holes are real close just need to cut the holes slightly and its a perfect fit. Ports are lmost exactly the same as well. So you can definitely make a turbo kit for the accord for around 1k bucks.
$300 obo..(trades are welcome)
Located in Middletown, NY 10941.
Hit me up on aim Solo Performance .
Old Jul 12, 2003 | 04:35 PM
SPEracing's Avatar
Default Re: FS or FT: F22 - Accord F22A6 Block and Head ĪPick UpĪ NY (SPEracing)
bump
Old Jul 18, 2003 | 07:54 AM
SPEracing's Avatar
$250 obo or trade.
theorigkav3
Aug 10, 2012 04:15 PM
robbizza
Nov 14, 2008 03:26 AM
drycreekgsr
Aug 11, 2006 07:53 PM
hondapwr
May 24, 2005 10:27 AM
