Missing piece in turbo project: HELP!!
Ok, a friend is working on a turbo project and there is a little part missing, maybe someone on here will have some different sources and can find one for me, all im looking for is a 12 mm banjo fitting with a 1/2 inch hose connection. http://www.atecautotechnic.co.uk/09/ part number 649.482 is what im looking for, its the 12 mm -8 about half way down the first table. Hopefully someone can find me this part without having to have it come from the UK. Ive searched just about everywhere i can only find this part from Italy, UK, and Germany.
Hopefully someone on H-T can pull through and get me a slightly closer one. Thanks guys.
btw, i dont need it to be anodised blue, this was just the cleanest page for an example one i could find.
i would dare to say that if it is for the turbo coolant fed that you should try turbo stores, or ask Art or maybe tell the Accord Mod to move this thread into the FI forum, they will be a lot more helpfull.
They probably are going to tell you that you should leave the coolant line out of it, but IMO you should connect the coolant line to the turbo.
Good luck
BTW what turbo is it?
Good luck
shong2
Jul 14, 2017 06:28 AM
