i finally installed my SPC ball joint camber kit.
Old Jul 11, 2003 | 06:48 PM
accordfreak's Avatar
Default i finally installed my SPC ball joint camber kit.
popping out the ball joint was the hardest thing i had to do... I had to use my freakin foot to put more weight on the vise so it'll pop out.. and so it did.. those of you who used a hammer.. i don't know how you did that because it was on there tight. other than that... it was pretty straight foward..
sorry for the poor quality pictures. I had to use my webcam because my friend is borrowing the digi...
on the vise..
installed finally.. the camber kit came with instructions... so it's not too hard.. just align it and bolt it on to spec
Modified by accordfreak at 10:48 PM 7/11/2003
Old Jul 11, 2003 | 10:31 PM
urbanlegend21's Avatar
New User
Default Re: i finally installed my SPC ball joint camber kit. (accordfreak)
this kit is really good guys, I put it through a grueling, abusive test this past weekend and it held up great
Old Jul 11, 2003 | 10:37 PM
im_the_teacher's Avatar
Default Re: i finally installed my SPC ball joint camber kit. (urbanlegend21)
is dat a fixed camber "V" arm?
or the adjusting ball joint?
Old Jul 11, 2003 | 10:38 PM
Accord94DX's Avatar
Default Re: i finally installed my SPC ball joint camber kit. (im_the_teacher)
does it bang on your frame at the top? where the nut is.
Old Jul 11, 2003 | 11:37 PM
ratherbewalking's Avatar
Default Re: i finally installed my SPC ball joint camber kit. (Accord94DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote">does it bang on your frame at the top? where the nut is. </TD></TR></TABLE>
id like to know this as well.
since were on the camber kit thing, does anyone have a camber kit on a 5th gen with 15's? if so is cutting necessary???? i havent bought a camber kit yet bc im afraid of the banging on the inner wheel wells
Old Jul 12, 2003 | 01:20 AM
i will find out tomrrow when I get my car aligned...
Old Jul 12, 2003 | 04:22 PM
sloaccord's Avatar
New User
this is SIMILAR but not the same, so take it for what it is.
i have a K-MAC kit, which is almost identical to this kit with the exception that the k-mac kit has 'wings' that run along the two arms of the control arm. i have it adjusted for near- 0 deg camber. it beat the hell out of the fenderwells until it beat them so much it no longer hit. sadly, it beat the kit into a pulp as well.
the K-MAC kit can be flipped so to run negative camber (say, track days, whatever) - which is a reason i got the kit, along with it having adjustable caster- but if i did this, it would stick the kit out so far it'd hit even worse. . . .
not the same kit, i know. but i felt like writing.
Old Jul 12, 2003 | 04:35 PM
Accord94DX's Avatar
thats the reason i threw my camber kit away. Much too annoying.
Old Jul 12, 2003 | 10:20 PM
well today at a accord meet i took the camber kit to the test.. we took a drive of hard driving through the mountains.. went through many bumps, dips big and small and hard turns. so far so good.
Old Jul 13, 2003 | 07:55 AM
honda607's Avatar
just curious where you got that kit and how much you paid, im about to lower my 94 lx adn i want a camber kit so i dont have to get tires 3 times a year, im looking for something that wont be hitting fenders. Thanks alot
Old Jul 13, 2003 | 02:01 PM
Default Re: i finally installed my SPC ball joint camber kit. (honda607)
http://www.groupbuycenter.com for 150 shipped. search for SPC
Old Jul 13, 2003 | 02:09 PM
AsiAnVenOm's Avatar
every accord has this problem...it bangs or not depend on how much you lowered your car...my logic is the more i lowered it...the more the arm has to extend to compensate...the more it extend the more it hits...I'm using Ingel Camber kit...i'm on my maximum 3 degrees now...and it still butterfly...
88CRXJ
13
Sep 30, 2009 09:35 PM
LagunaSecaEG
11
Sep 3, 2006 07:01 AM
TypeR 599
Feb 7, 2002 08:17 PM
