QUICK fuel pump question- need quick answer plz
I'm in the middle of this, pulled out the stock one and it's quite a bit larger than the Walbro 255 i got. Just wanna make sure this is correct before i stick this all back together. Thanks
Yeah , that's not a problem.
Make sure to install the pump at the absolute lowest you can on the bracket.
You might need a longer piece of hose, otherwise the pump will sit too high on the tank and you will have fuel starvation problems when the fuel level goes low.
I had to use a tie wrap to keep the pump in place in the bracket.
