lower tie bars
Old Jul 11, 2003 | 02:57 PM
SilverDC5's Avatar
Default lower tie bars
does anyone know what the difference in size of the lower tie bars for the rsx-s and the rsx-r?
Old Jul 12, 2003 | 02:04 AM
SlammedBlueEM2's Avatar
Default Re: lower tie bars (SilverDC5)
I don't think there is, and if I could find one on a US Spec DC5 (w/o the parts sheet), I don't think it would be much different.
Old Jul 12, 2003 | 05:49 AM
F1HONDA's Avatar
the USDM RSX doesn't come w/ a lower tie bar. i'm not sure if the JDM one does either. you sure you don't mean anti-roll bar?
Old Jul 12, 2003 | 07:05 AM
blackhawksi's Avatar
There isn't a difference. You can find the front and back lower tie bar for the DC5 at http://www.spoon.jp/eng or at http://www.takakaira.co.jp/bottom.asp.
Old Jul 12, 2003 | 10:36 AM
Default Re: lower tie bars (F1HONDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F1HONDA &raquo;</TD></TR><TR><TD CLASS="quote">the USDM RSX doesn't come w/ a lower tie bar. i'm not sure if the JDM one does either. you sure you don't mean anti-roll bar?</TD></TR></TABLE>
The JDM DC5R comes with one. It's a small flat bar mounted <u>under</u> the crossmember from the control arms. If I can find a pic, I will post it.
Old Jul 12, 2003 | 11:32 AM
Default Re: lower tie bars (SlammedBlueEM2)
This is the one I can't find on a DC5.
Old Jul 12, 2003 | 11:43 AM
DC5R
Old Jul 12, 2003 | 09:38 PM
SilverDC5's Avatar
thanks for all the input guys, i was just wondering because i wanted to improve the handling of my car.
Old Jul 13, 2003 | 10:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDC5 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the input guys, i was just wondering because i wanted to improve the handling of my car.</TD></TR></TABLE>
Tie bars don't improve the handling of your car. What it does is prevent a thick anti sway bar from flexing the crossmember so that the bar doesn't rip off of it. It's more of a safety tool. It has nothing to do with improving the handling on the car. Look at it. It's a little longer than your hand and probably no heavier than your hand either. It doesn't contribute to suspension dynamics whatsoever.
If you want to improve handling, toss the stock tires, lower the car on spring rates that aren't too soft or suit your need for handling and comfort, upgrade your struts and THEN put chassis stiffening bars on the car, i.e. strut, anti sway bars. These bars (especially anti sway bars) are used as a supplement for your springs, as spring rate & compression are the deciding factors of how well your car will handle.
00zzySi
14
Mar 5, 2010 04:51 PM
toolow69
Sep 25, 2006 07:34 AM
T"u"Rtle
Aug 25, 2006 06:45 AM
non vtec
Nov 15, 2002 10:42 PM
