Anyone running 4 piston caliper brake kits on their 90-3 Accords?
Old Jul 11, 2003 | 02:34 PM
se93's Avatar
Default Anyone running 4 piston caliper brake kits on their 90-3 Accords?
How's the braking? Worth the investment?
Thanks,
Mark
Old Jul 11, 2003 | 03:34 PM
93accordEX's Avatar
Default Re: Anyone running 4 piston caliper brake kits on their 90-3 Accords? (se93)
well his site is being updated so you can only see a couple pictures right now. not worth it for a street car imo.
http://www.zukko.com/julian/
Old Jul 11, 2003 | 03:48 PM
RotaryBzzzz's Avatar
Default Re: Anyone running 4 piston caliper brake kits on their 90-3 Accords? (93accordEX)
A better investment would be some better rubber first. F' the 4-pot upgrades until then. Were you planning on Brembo$??
In fact, its sooo far down the line in mods after suspension, braided steel lines, syn brake fluid and good rubber its almost pointless unless you can get them for free or close to it. Not trying to crap on your parade.
.02
Old Jul 12, 2003 | 04:21 PM
SearchBeforeUPost!'s Avatar
Default Re: Anyone running 4 piston caliper brake kits on their 90-3 Accords? (RotaryBzzzz)
i am upgrading to legend calipers and V6 rotors in the front, stainless lines all around, and converting the rear to disc (it was cheap and it looks better so don't hate).
i'll let everyone know how it turns out.
Old Jul 12, 2003 | 05:10 PM
smokin rubber's Avatar
I really dont know why you want to spend so much money on new calipers and rotors, stock stuff works great with the right pads.
Old Jul 12, 2003 | 10:14 PM
SIMATIC's Avatar
Default Re: (smokin rubber)
true....just add stainless steal lines to ur stock calipoers, prob will work just as good. with out spending so much on everything else.
wana stop at a shorter distance.? just press harder on the pedal @@
º
Old Jul 12, 2003 | 11:07 PM
Default Re: (SIMATIC)
the ss lines wont decrease stopping distances either, they only help wih pedal feel.
Old Jul 13, 2003 | 01:40 AM
TypeSH's Avatar
is that site w/ the brembo's "usc" from hondasociety/honda-acura.net?
in any case, if you have a 4th gen accord, you can choose a larger oem brake upgrade.
you may use a 4th/5th gen wagon rotor or 5th gen V6 rotor w/ any larger 11" rotor designed honda caliper for the fronts.
or you may use the 98-99 2.3 CL hubs w/ 3.0 CL rotors.
Old Jul 13, 2003 | 08:54 AM
Nick H's Avatar
New User
Default Re: (TypeSH)
calipers do matter...and those brembo's are ******* sweet...i dunno if any of you have ridden in an evo 8, but that thing stops in such a short distance and it does so over and over again...anyways, rubber does matter if you lock up your brakes, but the pads and calipers matter as well...if you wanna go fast, you gotta stop fast too...
Old Jul 13, 2003 | 12:03 PM
Default Re: (Nick H)
true. there is no way that just upgrading the stock pads will compare to a new caliper and rotor set-up. Its just illogical.
Sure, upgrading pads will work great for some people. But the bottom line is that bigger rotors and calipers will work even that much better.
I would rather have too much brake than just "adequate".
dpdawson
Honda Civic (2001 - 2005)
12
Sep 22, 2008 08:43 PM
mooseheads36
Honda Civic (2006 - 2015)
33
Apr 20, 2007 04:54 AM
intxactdgsr
Oct 19, 2005 02:03 PM
XyKo
Feb 8, 2005 02:52 PM
EG*MonKEY
Jan 6, 2004 10:08 PM
