Ebay alarm system(delta) w/LCD pager, is it any good?
Old Jul 11, 2003 | 06:29 AM
allmotorEG-SI's Avatar
Default Ebay alarm system(delta) w/LCD pager, is it any good?
Here are some pics. its a delta and only about $123. Do you think its worth it?
here are the features from the ad: Includes One Ultra Small FIVE Button Multi-Channel Pager Remote
One 4 Button Standard Remote
0.7 or 3 Second Door Lock Pulse (Programmable)
Code Learning Receiver
Anti-Scan Technology
Alarm Pre-Warning
Defective Zone Bypass with Warning Chirps
Remote Panic
Starter Disable Protection (Relay Required)
On-Board Flashing Light Relay
LED Status Indicator (Plug-In Design)
Protected Valet/Programming Switch (Plug-In Design)
6-Tone Mag 125dB Electronic Siren
Passive or Active Arming Mode (Programmable)
Door Lock on Passive Arming (Programmable)
Auto Lock/Unlock through Ignition (Programmable)
Graphics Display Armed or Disarmed State, Zone Violation, Vehicle Running After Remote Start, and Valet/Service Mode
433 MHz Transmitter Frequency for Less RF Interference and Added Reliability
Penetrates through most Cement Structures,Movie Theaters,Malls,etc..
Digital Transmission Format Permits Real-Time Instant Confirmation of Arm, Disarm, Start, and Intrusion
Valet Button Operates as an In-Vehicle Call Button to the Transceiver
On-Board Relays for Easy Installation
Selectable Engine Speed Sensing: Tach Learning, Tachless, or Vacuum Operation
Gas or Diesel Engine Operation
Hood Open Safety Circuit.The Unit will not Remote Start if Hood is Open or Ajar
Factory Alarm Disarm Feature. Disables Factory Alarm Before Remote Starting if Necessary
Outputs for Additional Ignition Relays if Needed
Three Start Attempts
Automatic Transmission, Fuel Injected Vehicles ONLY!
Old Jul 11, 2003 | 08:24 PM
so no one has any experience with this...
Old Jul 12, 2003 | 07:20 PM
Aquaman's Avatar
Default Re: (gixxerdemon)
I haven't heard of anyone using it. I would just assume that you get what you pay for, but with alarms, its only as good as the install.
joe.wong321
Feb 25, 2008 05:21 AM
Hanmin
Audio / Security / Video
Nov 29, 2007 11:19 AM
Outsane
Sep 11, 2005 07:28 AM
