accord shakes, what might be wrong?
Old Jul 11, 2003 | 06:28 AM
professorman's Avatar
Default accord shakes, what might be wrong?
My accord used to shake at 55-70 MPH. I got a 4 wheel ballance done at Pepboys, now it shakes at 70-75MPH. it does not shake as bad as it did before, but there is still a shake. What else might be wrong? what could i check? i had new axles and an alignment done about 3 months ago.
Old Jul 11, 2003 | 06:55 AM
btlfed1's Avatar
Default Re: accord shakes, what might be wrong? (profroopchan)
could have a bent wheel. Might want to check the alingment again though.
Old Jul 11, 2003 | 11:15 AM
Default Re: accord shakes, what might be wrong? (btlfed1)
could it be the axles or anything? because i have 17" rims on my car now, and it did the same when i had the stock rims on.
Old Jul 13, 2003 | 08:07 PM
olds_442's Avatar
I've had trouble with tires. A slipped belt will create a vibration. Also check the wear... had one tire cupping causing a vibration.
Try rotating your tires and see if the vibration moves around. If it does problems with your tires, if it doesn't its in your suspension.
Old Jul 14, 2003 | 07:18 AM
zeta_msz_006's Avatar
Check your engine mounts also.
Old Jul 14, 2003 | 07:38 AM
r1emperor's Avatar
It still needs balancing. You said that when you balanced it the shake moved to a different speed.
Old Jul 14, 2003 | 12:35 PM
Default Re: (r1emperor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1emperor &raquo;</TD></TR><TR><TD CLASS="quote">It still needs balancing. You said that when you balanced it the shake moved to a different speed. </TD></TR></TABLE>
That's what i was wondering. I was wondering if when it is balanced, if it was possible that it was not balanced properly?
Old Jul 14, 2003 | 09:37 PM
r1emperor's Avatar
yep
Old Jul 14, 2003 | 11:29 PM
FREAKquency04's Avatar
you could also have warped rotors
Old Jul 15, 2003 | 07:03 AM
Default Re: accord shakes, what might be wrong? (AcCorDH22ARaCeR)
i know that my rotors might also be warped. but i think that independent of that, something else might be wrong. it shakes when i brake from 65 ~ 50 MPH
Old Jul 15, 2003 | 03:29 PM
preluder's Avatar
dents in the rim lumps on the tire,bad fuel consumption causein it to lean out,
Old Jul 15, 2003 | 04:22 PM
RotaryBzzzz's Avatar
Does this car ever sit parked for months?
Old Jul 15, 2003 | 04:27 PM
DrunkNRacer's Avatar
Default Re: accord shakes, what might be wrong? (RotaryBzzzz)
If.. when you slow down.. it shakes... it should be a bent wheel.. I have the same problem.. thankgod I got some new ones..
So try and rotate them around.. and see if the shake transfers to another side.. Its probably a front wheel.. so move the 2 fronts to the back..
Old Jul 15, 2003 | 05:03 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcCorDH22ARaCeR &raquo;</TD></TR><TR><TD CLASS="quote">you could also have warped rotors</TD></TR></TABLE>
Yea... warped rotors would be your best bet... Check your lug nuts and see if they are tightened straight and to the correct torque specs
Old Jul 16, 2003 | 09:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzzz &raquo;</TD></TR><TR><TD CLASS="quote">Does this car ever sit parked for months?
no, it does not sit parked
Old Jul 16, 2003 | 09:26 AM
Default Re: accord shakes, what might be wrong? (G-villeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">So try and rotate them around.. and see if the shake transfers to another side.. Its probably a front wheel.. so move the 2 fronts to the back.. </TD></TR></TABLE>
Ok, i'll try that
Alpaca
Jun 6, 2019 04:40 PM
sneaks
Feb 28, 2010 09:04 PM
cb1999nj
Oct 16, 2007 07:05 AM
dolllover
May 2, 2007 10:12 AM
ch4nq
May 25, 2006 09:51 AM
