ECU question
I have Kenjis p28 OBD 1 ECU's and I need to get my emmsions done. Which integra models/years can i plug into my car to have it pass and still have the car run for that day. Will a 91, 92, and 93 DOHC integra's ECU do the trick. Thanks!
if they do ecu test/scan for obd2 ecu.. then you need to obtain obd2 ecu, if they don't do ecu check, then it doen't matter what you run as long as it can pass through dyno test.
