how to get alittle more, not too expensive or too much labor HP after i/h/e
Old Jul 10, 2003 | 09:54 PM
Loveless's Avatar
Default how to get alittle more, not too expensive or too much labor HP after i/h/e
say I have i/h/e
what's the next step?
I want to spend maybe around 300 on something
intake manifold seems too much work
stage 1 cams shouldn't be too much work to replace but will result in bad idle right?
let me know what you guys think
RedGSR's Avatar
driving school
Old Jul 10, 2003 | 09:57 PM
timmy8151's Avatar
Default Re: how to get alittle more, not too expensive or too much labor HP after i/h/e (Loveless)
When doing bolt on mods, people always forget the C in I/H/C/E, which stands for cat. Upgrade to a hi-flow cat, because your stock cat could possibly be choking your airflow. Also, tune your car to get the most benifits out of your mods.
Old Jul 10, 2003 | 10:35 PM
B2FiNiTY's Avatar
Cams will not give you a bad idle. Depends how you tune it and how agressive they are. Get a VAFC and get your car tuned. Should be a tad over 300.
Old Jul 10, 2003 | 10:37 PM
JDMB16DA6's Avatar
Not always the case with cams. "Stage 1" is a very loose term though. What kind of setup do you have now? What car/motor? I have a B16 in my '91 Teg and I just did a CTR cam upgrade. Power over stock is awesome and the idle is smooth as silk. I have also heard that TOda Spec A's, Skunk2 Stage1 and Spoons have very good idles. HOwever, remember that you can't just do cams. Everything else that directly works with the cams has to be upgraded as well (e.i., valve springs, FPR, ECU chip). Cams alone may hurt you.
But yes, cams is a good choice.
~B
Old Jul 11, 2003 | 10:47 AM
Loveless's Avatar
is there any cams that will offer gains, does not idle weird, and works fine without other engine work?
Old Jul 11, 2003 | 10:50 AM
Aaron M's Avatar
cat
Old Jul 11, 2003 | 10:54 AM
quikB18B's Avatar
Default Re: (SilverB18C1)
Get a cat, or if u want cams get some Type R cams, then a vafc and tune. No need to get car tuned with i/h/e all you did was free up air flow from the stock restricted parts.
Old Jul 11, 2003 | 11:10 AM
redlinegsr's Avatar
Default Re: (quikB18B)
Underdrive pulley. around $160 for a good one.
Old Jul 11, 2003 | 12:37 PM
Loveless's Avatar
Default Re: (redlinegsr)
this will sound dumb but it's ok to mix and match itr cams into a ls block? since one is vtec and one's not?
Old Jul 11, 2003 | 01:07 PM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr &raquo;</TD></TR><TR><TD CLASS="quote">Underdrive pulley. around $160 for a good one. </TD></TR></TABLE>
Do the pulley really work to produce HP? I have heard mixed reviews about these.
Old Jul 11, 2003 | 01:32 PM
dohc-nyne's Avatar
ive heard of crank pulleys producing about 5 or 6 hp to the wheels on a b16 si......
just as when u cut the ac belt or power steering belt it frees up force used to drive those pulleys...so if u replace your stock pulleys with larger diameter lighter ones it frees up force used to drive the belts
Old Jul 11, 2003 | 01:38 PM
jspec21's Avatar
Default Re: (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">this will sound dumb but it's ok to mix and match itr cams into a ls block? since one is vtec and one's not?</TD></TR></TABLE>
what do you mean? You can use a ctr intake and a itr exhaust cam, but if you don't have vtec then you can't use vtec cams.
Old Jul 11, 2003 | 01:51 PM
notstock93's Avatar
Default Re: (jspec21)
He has a B18B...so there goes the type-r cams idea. My .02 is to get a hondata, and have your car dyno tuned. I have 404's and the power isnt that great (i still have LOTS of tuning to do, but...) so I wouldnt get cams untill ou do a ton of research and are ready to drop a good sum of money to get all of the parts that go along with them. Then add tuning on top of that.
Old Jul 11, 2003 | 05:22 PM
JDMB16DA6's Avatar
Default Re: (notstock93)
B18B! Well so much for the quick and easy. As notstock93 said, there is much homework to be done before modding an LS motor. Too little tuning and you won't be happy. Too much tuning and the car won't be streetable.
**CAREFUL WITH PULLEY'S**
Key words here; Harmonic Balancer. Your stock crank pulley is perfectly balanced to keep the motor from vibrating apart. Aftermarket pullies may free some horsepower, but you may start to blow out seals and bearings. This is only advice for the crank pulley! Anything else is fine. DO NOT change your crank pulley with a lightened one. $.02
Old Jul 15, 2003 | 09:56 AM
notstock93's Avatar
Default Re: (JDMB16DA6)
The stock Crank pulley IS NOT perfectly balanced. It is fairly balanced, sure, but the pulley has a rubber inner lining that dampens the vibrations....not the actuall balance of the pulley. In fact, D series and B16 pulleys dont even have the rubber stripping.....the engines are small enough that the vibrations dont even need THAT.
Old Jul 15, 2003 | 10:49 AM
StyleTEG's Avatar
http://www.inlinefour.com/infourn1encr.html
Inline four balanced crank pully is lighter, is balanced, and still has the rubber dampener.
mike1jag
Oct 24, 2007 07:39 PM
Yusuke
Dec 30, 2004 08:09 AM
Deetz
11
Dec 16, 2004 11:27 AM
95 integra
Feb 21, 2004 08:32 AM
PYITR821
Jan 21, 2003 04:52 AM
