Bad scratch...can i touch it up to look perfect?
Old Jul 10, 2003 | 05:00 PM
JM Performance's Avatar
Default Bad scratch...can i touch it up to look perfect?
I have a 1" scratch to the metal on my fender. If i take my time and get touch up paint, clear coat, the right sand paper, and rubbing compound is it possible to fix it to near perfect?
Or should I take it to a pro? They're gunna wanna do the whole panel though... Is it possilbe for them to just fix that spot?
BTW its vogue silver.
Old Jul 11, 2003 | 08:14 AM
SIK IN DA HED's Avatar
New User
Default Re: Bad scratch...can i touch it up to look perfect? (00SilverLS)
not worth it to make it look perfect. just get touch up paint and try to paint it as clean as you can.
Old Jul 11, 2003 | 09:00 AM
Tweakmeister's Avatar
you can make it look pretty good with enough effort.
I'd get a couple new pencils and glue hole punched pieces of sandpaper to the eraser.
Old Jul 11, 2003 | 09:07 AM
tilt's Avatar
Default Re: Bad scratch...can i touch it up to look perfect? (Tweakmeister)
Someone keyed my car pretty bad and I dont want it to rust. What grit sandpaper is recommended if I do the DIY method? tia
Old Jul 11, 2003 | 09:49 AM
acuracy90's Avatar
Default Re: Bad scratch...can i touch it up to look perfect? (tilt)
I would get it done professionally. No touch up paint will ever look as good as a pro job. Keep it perfect.
Mike
Bxjay16
Paint and Body
Dec 23, 2011 09:03 AM
CrxChicken
Jun 16, 2011 08:40 AM
PolishSasquatch
Paint and Body
Sep 8, 2010 06:04 AM
Masta
Paint and Body
27
Jul 2, 2007 02:15 PM
Beave0101
Jan 20, 2004 06:28 PM
