Porting Type R Throttle body..need some info
Old Jul 30, 2001 | 07:08 PM
flex97itr's Avatar
Default Porting Type R Throttle body..need some info
My questions are:
1.How much can i safely port an ITR tb so its evenly ported througout?
2.Do i hafta polish it up afterwards?
3.Which gaskets do i use? Can i use OEM honda gasket?
4.Do I hafta get a new throttle plate ?
thanks in advance.. any info would be greatly appreciated
Old Jul 30, 2001 | 08:08 PM
kenji's Avatar
25 Year Member
Default Re: Porting Type R Throttle body..need some info (flex97itr)
1. The largest consistent bore ITR TB I have seen is about 65 mm. I know, I know Spoon claims 70mm. That is tapered at 70mm and goes back down to 62mm.
2. No need to polish it up if a good cutting tool is used on a lathe. You are going to use a lathe, aren't you?
3. You can use the OEM gasket
4. If you increase the ID (inner diameter) of the TB you will definitely need a larger throttle plate.
If you want your TB done right call Vernon at RaVer Motorsports at 559-733-4711. Be sure to tell him Kenji sent you. Good luck.
-kenji
Old Jul 30, 2001 | 08:15 PM
flex97itr's Avatar
Default Re: Porting Type R Throttle body..need some info (kenji)
any idea on how much? shouldnt i also port match my manifold as well?
eg2jr
Oct 4, 2009 06:10 AM
blue2000em1
45
Dec 1, 2007 12:09 AM
precisionelite
Apr 23, 2006 04:59 AM
ScottEK
Sep 2, 2005 06:22 AM
Mikey3000
May 28, 2002 04:06 AM
