MY RADIO BROKE
Old Jul 10, 2003 | 01:29 PM
monhondatero's Avatar
Default MY RADIO BROKE
My radio blew out the other day and I dont know how to fix it. CAN SOMEBODY HELP! please, i changed the fuse but it only gave it a little power and blew out again. What up with that yo!
Old Jul 10, 2003 | 02:15 PM
YeuEmMaiMai's Avatar
need a little more information
factory or aftermarket?
did you change anything.. is there anything else on that fuse?
Old Jul 10, 2003 | 04:14 PM
91according's Avatar
Default Re: (YeuEmMaiMai)
just put another one in unless itis aftermarket already if not just through a new one in bring it to a shop and they can proly fix the problem
Old Jul 10, 2003 | 07:31 PM
The radio is factory and its not under warranty anymore . So it sucks cause i drive around with no music. BORING! Can someone give me some insight on what might be wrong.
Old Jul 10, 2003 | 11:08 PM
Heat's Avatar
Still need some more information:
What is the year of your Accord? Is this a cassette player or CD player? What happened immediately before it blew (were you just listening to music, did you just turn on the radio, was the music cranked, etc)?
When you put in the new fuse, how long did it run before it blew again? What size of fuse did you put in?
Old Jul 11, 2003 | 06:17 AM
Default Re: (Heat)
I have a 97 civic. Just one day i was listening to the radio (not very loud) -medium- and it stopped working. When i put a new fuse in like 3 seconds later it blows out. Do you think maybe its a wire somewhere? There is also a cd changer hooked up to it but that hasnt worked in ages. the cds keep getting jammed. (stupid car) Its not a cassette player radio only
Old Jul 11, 2003 | 08:14 PM
phateless's Avatar
Default Re: (monhondatero)
tear into it and start checking wires. could be a bad ground or a short circuit or something? are you using the same resistance fuse that was in there at first? pull out the deck and check all the wires. process of elimination at this point. hell, even check your speaker wires. if the + and - touch each other it can cause a nasty little spark. most decks should have some kind of failsafe for that but...i don't know it's an idea. if you can, plug another honda deck into your car and see if you have the results?
JuicedUpRice
Nov 10, 2012 10:04 AM
MadHatter973
Feb 18, 2010 05:02 AM
simplegreenmachine
Audio / Security / Video
Aug 17, 2007 07:42 AM
greendragon
Jul 10, 2005 06:00 AM
Greenery18
Aug 31, 2004 10:05 AM
