Axle won't come out of LS. help!!
I'm trying and trying, but I can't seem to get the axle out from the driver side of my 97 LS. I got the passenger side easy, but I cant pop out this side. I cant just pull on it cause the inner bearing and joints came out. So all I got left is the inner part. Is there a trick to getting it out? That intermediate shaft doesnt give me any leverage points.
help!! thanks!
//Jesse
help!! thanks!
//Jesse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cardriver »</TD></TR><TR><TD CLASS="quote">I had the same problem.. try using a crowbar (the flat-head side) and a hammer to tap it loose. Worked for me.</TD></TR></TABLE>
well thanks for the help
I ended up doing what you did and got it out, but before I checked your post.
thanks tho!!
thanks tho!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack »</TD></TR><TR><TD CLASS="quote"> I cant just pull on it cause the inner bearing and joints came out. </TD></TR></TABLE>
gl getting those back in...its a real PITA, took me forever...they have to go in EXACTLY right :/ (i assume youre talking about the half shaft that came apart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg01 »</TD></TR><TR><TD CLASS="quote">
gl getting those back in...its a real PITA, took me forever...they have to go in EXACTLY right :/ (i assume youre talking about the half shaft that came apart)</TD></TR></TABLE>
thanks, but im replacing the whole axle.
yea yea take the easy way out
</TD></TR></TABLE>yea yea take the easy way out
