Different types of wall-mounted MAP sensors?
Old Jul 10, 2003 | 10:19 AM
KinGClowN's Avatar
Default Different types of wall-mounted MAP sensors?
I have an '88 Si that flashes a check engine light once a month for about a day then goes away. The computer is showing me 3 red flashes which is a MAP sensor correct? Well a new MAP sensor is $254 and I saw a MAP sensor from an '89 Si on ebay which I picked up for $30. Now the problem is that the MAP sensors are different, the new one has a 36000-PM6-AO2 9B on it where the other is 36000-PM6-AO1-8B. The type of connector for the top left hand sensor is also different. I was under the impression that any wall mounted MAP sensor would work. Is that not true? ANy help is appreciate, thanks.
Old Jul 14, 2003 | 02:59 PM
KinGClowN's Avatar
Default Re: Different types of wall-mounted MAP sensors? (KinGClowN)
bump
Old Jul 14, 2003 | 03:40 PM
dester223's Avatar
I have a spare firewall mounted map sensor. You can even use the newer throttle body mounted map sensors. Same 3 plug connector.
-Chuong
journeyquest
Jul 23, 2014 02:58 AM
reddysol
Sep 8, 2007 10:57 AM
methos713
Jun 11, 2007 12:43 PM
