1993 Civic hatch 10 second All Motor drag car
93 Civic Hatch - 10 second All Motor car
Reason for selling my race car: Trying to buy a house and cannot afford to continue racing.
Race History:
Best ET- 10.76, 10.78, 10.79 (When wheelie bar is tuned/dialed-in projected to drop at least 2 tenths off these times)
Best MPH- 124.8
1st Place- 3 times
2nd Place- 2 times
Semi- 5 times
2.0L Erick's Racing built motor making 265hp and 160tq to the wheels.
- Toda D spec cams
- Toda cam gears
- Toda valve train
- Alaniz ported GSR head
- Alaniz intake manifold
- ERE throttle body
- ERE header
- JE pistons (ERE specs 85mm)
- Eagle Rods
- RC 440cc injectors
- KOYO aluminum radiator
- HASport motor mounts
- Iceman ram air intake system
- Paxton fuel filter
- Fuel cell
Transmission
- B18C1 bottom end
- JDM B16A tranny
- ITR LSD
- ATS 4.929 final drive with ATS fisrt gear
- Tilton clutch with chromo flywheel
Chassis/Suspension /Wheels
- Tubeframe from firewall back (1445lbs without driver)
- Custom under chassis wheelie bar (not yet dialed in)
- Custom front/rear suspension
- Bogarts 13x8 front and 15x4 rear
- Slicks M&H 25x8.7x13 front and MT 24x4.5x15
- MB fiberglass doors
- MB fiberglass front end
- Skunk2 top A arms
- Sprint racing seat
- Sparco quick release steering wheel
- Simpson 5-point racing harness
Electronics
- Hondata s200 with datalogging and 3-step
- P28 ECU
- Autometer playback tach
- Autometer oil pressure, fuel pressure, water temp, and volt gauges
- Rear brake line lock system
- MSD external fuel pump
- External water pump
Asking $16,000
Race History:
Best MPH- 124.8
1st Place- 3 times
2nd Place- 2 times
Semi- 5 times
- Toda D spec cams
- Toda cam gears
- Toda valve train
- ERE throttle body
- ERE header
- Eagle Rods
- Fuel cell
Transmission
- B18C1 bottom end
- JDM B16A tranny
- ITR LSD
- Skunk2 top A arms
Electronics
- P28 ECU
Asking $16,000
White Dragon
Aug 31, 2001 01:28 PM
