Hey ITR Tuners, got some questions that only u guys can answer
I have a 2001 GSR. My setup right now is:
Skunk2 Type R style intake manifold
Type R AEM CAI
JUN Type 3 Cams, valvesprings and titanium retainers
DC Sports 4-1 CC Header
Type R Catback exhaust with 2.5 inch cat
2000 ITR ECU
VAFC
This weekend I will be installing JDM ITR Pistons (11:1) in a GSR block that equivalates to about 11:8 or 12:0 compression. The rods are shotpeened. My question is should i be close to 200 Whp and 130 pds of torque. My goal is to also get into the 13's (with slicks). Whats your guys opinions. I nearly gace up on the JUN cams, but it was my error due to the fact I thought they would just slap in and give me horespower. Those cams require at least 11:1 compression, as they bleed off compression, and in a GSR the stock pistons just dont cut it.
Type R AEM CAI
2000 ITR ECU
VAFC
You need to bump the pressure to around 65psi with line off, plugged.
I doubt you will be at 200whp, probably around 190whp. You should be in the 13s with less mods than you described.
lilo_goki
22
Jun 27, 2010 07:09 PM
R.and.Y
Nov 6, 2006 09:27 AM
J2turbo21
25
Jul 29, 2004 02:49 PM
Combustion Contraption
17
Aug 29, 2003 06:50 PM
