Camber Issues! Which one to get?
Old Jul 10, 2003 | 06:03 AM
b16_madman's Avatar
Default Camber Issues! Which one to get?
My 88 hatch w/b16:
It's ridin on h&r "race" springs 2.25f/2.00r
I never got an alignment after I put on the springs, me.
Now my tires are worn down funny, well besides being bald from my right foot.
-The front two tires have about an inch worn down on the inside of the tires, kinda like rollerblade wheels.
-And the back two are worn down about a 1/2 an inch.
I've heard of the Home Depot rear camber kit, but I could use some more specifics on it.
And what kind of camber kit are H-T'ers runnin here?
OR, could an alignment solve this issue?
Thanks...
Old Jul 10, 2003 | 09:25 AM
slowpokesi's Avatar
Default Re: Camber Issues! Which one to get? (B16_madman)
im using the same springs,
the alignment could solve the problem, sounds like your "toe" is out of whack
anyhow i got the ingals extreme in the front for 120 shipped at adrperformance.
and the alignment for 60.00 at ntb.
Old Jul 10, 2003 | 11:35 AM
b16_madman's Avatar
Default Re: Camber Issues! Which one to get? (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your "toe" is out of whack</TD></TR></TABLE>
yeh. that could be some of the problem. my front left lower control arm has been bent for about a year, and i just replaced it w/a straight one, so now it pulls madly to the right.
Old Jul 10, 2003 | 12:11 PM
E-AT_me's Avatar
dude.. it's caused by toe.. i have -2.7 camber in the front.. no problem with wear..
Old Jul 10, 2003 | 01:16 PM
REDBARON's Avatar
Default Re: Camber Issues! Which one to get? (Rexman)
I have the Ingall's extreme camber kit in the front, and the bolt and washers trick in the back.
I you want to find out exactly how the rear camber is fixed, just do a search on here. That's how I found out initially.
Old Jul 10, 2003 | 05:58 PM
tsjeff's Avatar
Default Re: Camber Issues! Which one to get? (REDBARON)
if you raise the car higher up will the camber be corrected or will it just stay the same? i have camber problems but im trying to find a way to correct it.
walsh22
Mar 16, 2007 05:56 PM
sixtodc2
Mar 5, 2006 04:57 PM
chronodyne28
Oct 24, 2004 07:03 PM
00-0258
Jun 18, 2003 09:19 AM
Kryptonite
Jan 3, 2003 09:55 PM
