Some pics of my rig (56k go to hell)
Racecraft Eng... Built the Factory Mazda Gp2 Car, Neon, tube frame Porches, Sand drag cars, all sorts of great stuff
Excellent work....
Ahem... If anyone needs excellent fabrication in the west Michigan area, give Chad at Racecraft Engineering a call..
Excellent work....Ahem... If anyone needs excellent fabrication in the west Michigan area, give Chad at Racecraft Engineering a call..
Extremely nice cage...kudos! The sheet gussets are sweet since your rules allow it. For wheel to wheel stuff I'd think the top door bars are a bit low to keep cars from coming in over the top but for rallying hopefully trees won't be trying to join you in the cockpit. Hopefully the only cars you meet up with will be passing when you catch the guy in front of you. Nice piece of work.
On a directly related topic, I finally found pictures of a cage executed with A-pillars the way I have been drawing them for the last two years. These are from a factory GrN VW Polo 4...
Pics are from http://www.vwmotorsport.com/pologallery/index.htm
Kirk
Kirk
I've come to realize that rally cage builders are really, really good at building cages. I guess when flipping your car at high rates of speed violently through trees and cliffs is involved, they kinda have to be. Someone at the shop I go to is getting his cage done by an ex rally co driver/car/cage builder, and it's sitting in the car, assembled, but unwelded, and still together.
SlowWhiteEvo
May 22, 2004 02:52 PM
confusedJDMvwGTI
Aug 7, 2003 11:10 PM
