NEW! SUBS/AMP/WIRE/AMP KIT Car Audio System
SPECIFICATIONS:
Amplifier (LA290):
4 Channel Amplification
4 x 100 Watts Output
400 Watts Total Output
2 Ohm Minimum Impedance
Polished Chrome Finish
Variable Gain Control
Remote Turn On/Off
Hi/Lo Level Inputs
Power On Indicator
LED Protection Indicator
S/N Ratio: >80dB
THD: <0.4%
Frequency Response: 25Hz-20k Hz
Thermal & Short Circuit Protection
Dimensions: 2"H x 11"W x 9.2"L
2 Subwoofers (LWF12X):
12 Inch Subwoofer
Impedance 4 Ohms
500 Watts Peak Power
250 Watts RMS Power
TI Poly Cone
1.5" Kapton Voice Coil
Mounting Depth 4.92"
Frequency Response: 20Hz - 2.5k Hz
Bumped & Vented Motor Structure
Magnet Weight 80 Oz.
Amplifier Kit (LAMP1):
In-line See-Thru Water Resistant AGU Fuse Holder
20ft. 8 Gauge Wire
4ft. 8 Gauge Ground Wire
20ft. 16 Gauge Remote Turn-On
20ft. 12 Gauge Wire
20ft. Right Angle Interconnect Audio Cable
6ft. Black Cable Conduit
60A AGU Type Fuse
Accessories:
Resistant On-line Fuse Holder
AGU Fuse Holder
Terminals: 8G
Spade Terminals: 8G
5 Spade Terminals: 14-16G
3 Butt Connectors
20 Cable Ties
1 Black Grommet
New $300 ship
Amplifier (LA290):
Remote Turn On/Off
Hi/Lo Level Inputs
Power On Indicator
S/N Ratio: >80dB
THD: <0.4%
12 Inch Subwoofer
Impedance 4 Ohms
250 Watts RMS Power
TI Poly Cone
20ft. 8 Gauge Wire
20ft. 12 Gauge Wire
60A AGU Type Fuse
Accessories:
AGU Fuse Holder
Terminals: 8G
Spade Terminals: 8G
3 Butt Connectors
20 Cable Ties
1 Black Grommet
New $300 ship
