Check engine light after MUGEN Head gasket?
I installed a MUGEN head gasket and I am getting a check engine light. Does anyone know of any issues with this gasket. My friend said it might have to do with the fuel pressure since the car has higher compression now and that I should probably purchase a fuel pressure regulator to make sure I am getting the correct pressure.
Other mods - CAI, DC JDM 4-1, Carsound Cat, MUGEN cat-back and TODA Cam gears.
Humm ok, So then I should set my timing back to stock because after installing the gasket I actually bumped it up 2 degrees. So that means that my timing is that much more advanced.
