Energy Suspension Bushings
Old Jul 9, 2003 | 05:46 PM
HybridEL's Avatar
Default Energy Suspension Bushings
Hey, i was just wondering how much of a difference the urethane energy suspension bushings would make on a 90 crx si
is it a mod that i should do sooner........ or later?
Thanks!
Old Jul 9, 2003 | 06:14 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Energy Suspension Bushings (d0pEy)
If you drive turns and not just in straight lines then you will feel the improvment along with all the little bumps in the road you never knew were there. If you are doing sus work anyway and you need to replace some worn out sus rubber then poly replacements are probably the way to go. If you don't want that rough ride stick to rubber replacements.
Old Jul 9, 2003 | 07:43 PM
90civichbsi's Avatar
Default Re: Energy Suspension Bushings (4drEF)
i have them and they made a difference in both turns and straight lines, wheel hop was reduced alot. For the money it was the best suspension mod i have done. It was alot of work but well worth it.
Old Jul 9, 2003 | 08:05 PM
HybridEL's Avatar
Default Re: Energy Suspension Bushings (90civichbsi)
thanks guys
i plan on upgrading when i redo my suspension setup
dc2_4life
Suspension & Brakes
29
Jun 11, 2009 12:39 PM
Flux
Dec 1, 2003 04:11 PM
jdmcivicferio
Dec 22, 2002 08:07 PM
