Type R rods better than GSR Rods?
Old Jul 9, 2003 | 05:44 PM
ScottFern's Avatar
Default Type R rods better than GSR Rods?
Alright, I have a possible deal for some USDM ITR pistons/rods/piston rings already mounted new for 200, but I want to know if I should just go for some higher compression pistons.
What is the advatanges of the ITR rods, and do I really need them if I am only reving too 8600-8700 with my stage 2 cams in my gsr engine??
Old Jul 9, 2003 | 05:57 PM
RTW DC2R's Avatar
Default Re: Type R rods better than GSR Rods? (ScottFern)
GSR rods should be fine.
Old Jul 9, 2003 | 06:12 PM
ScottFern's Avatar
Default Re: Type R rods better than GSR Rods? (RTW DC2)
What are the advantages to Type R rods, anything, I don't know why they made them if gsr rods are fine till 8700rpm ???
Old Jul 9, 2003 | 06:15 PM
216.226.142.95:27016's Avatar
itr rods are heavier due to more weight for better rotating balance. something like that.
Old Jul 9, 2003 | 06:30 PM
SlapSmak's Avatar
Default Re: Type R rods better than GSR Rods? (216.226.142.95:27016)
ITR rods are lighter, stronger, shotpeened for hardness and balanced. GSR rods are not.
Old Jul 9, 2003 | 07:36 PM
Eva01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">itr rods are heavier due to more weight for better rotating balance. something like that.</TD></TR></TABLE>
You're thinking about the crank. ITR is heavier because it is counterweighted for smooveness at higher RPMs.
Old Jul 9, 2003 | 08:09 PM
Spoond TEG's Avatar
Default Re: Type R rods better than GSR Rods? (Eva01)
Itr Rods are lighter. However if you are changing the rods with the pistons it is necessary to replace the bearings and I am not sure if the Color codes will be the same since the ITR rods had double digits and the GSR rods are single digits.
Since the Crank is a GSR Crank the letters on the crank are A B C D while an ITR Crank is T-Z so that something to think about. Also the Rods and Pistons may be 200 but add in the cost of the bearings and that will rise.
Old Jul 9, 2003 | 08:12 PM
canuck-mx6's Avatar
Default Re: Type R rods better than GSR Rods? (Spoond TEG)
Bah, just plastigauge to check the clearances. I am using shotpeened GSR rods, and they are fine. Everytime I drive my car (which isn't a whole lot), I see 9K +, and I have not had a problem yet
Old Jul 11, 2003 | 06:44 AM
Spoond TEG's Avatar
Default Re: Type R rods better than GSR Rods? (canuck-mx6)
Personally I would change the Bearings anyway, but that's just me I'm particular like that.
Chillinit
Sep 28, 2004 07:51 AM
SioneSi
Aug 5, 2004 04:22 PM
sublimnal
Apr 1, 2004 05:30 PM
SSBP DC2
Jul 2, 2003 07:08 PM
bb6
14
Jun 4, 2003 10:34 AM
