cost to port R motor?
Old Jul 30, 2001 | 11:48 AM
F120man's Avatar
New User
Default cost to port R motor?
i wanna port an R motor. how much would i cost to do so? for intake/head/block. also is it recommended to port if i go force induction?
Old Jul 30, 2001 | 11:58 AM
yoshi234's Avatar
I shoot brides
Default Re: cost to port R motor? (F120man)
check out http://www.portflow.com
i've only heard g00d things about them
-y
Old Jul 30, 2001 | 11:59 AM
EPGONZALEZ's Avatar
the r motor has a decent port from the factory..port matching is the only real thing you should do..its usually very expensive..because its all labor..heads usually a grand and up..intakes manifolds usually done when you take in your head..as far as the block goes..i never seen one ported..lol..but they do massage them..take out all the casting imperfections so water will flow better and oil wont build up..but that also $$ hope this helps..honda ports are close to perfection..
Ludcifer
Apr 26, 2010 08:05 PM
ALLMOTORD16Z6
Aug 4, 2005 01:25 AM
E Swift
Jul 10, 2001 11:44 AM
