Bad Brake Booster Check Valve?
Old Jul 9, 2003 | 01:43 PM
FourthGenHatch's Avatar
Default Bad Brake Booster Check Valve?
For some reason all the sudden when I press the brakes on my car to stop now the pedal sinks. I know it is full of fluid, and I'm pretty sure there is no air in the lines as I haven't messed with my brakes in a year. So when I press the pedal down I have to pump it a couple times to come to a complete stop. Do you think it could be that check valve? Seems to me like I'm not getting good vacuum so maybe that is not holding it in.
Old Jul 9, 2003 | 01:55 PM
slowpokesi's Avatar
Default Re: Bad Brake Booster Check Valve? (FourthGenHatch)
master cylinder
Old Jul 9, 2003 | 01:57 PM
Default Re: Bad Brake Booster Check Valve? (slowpokesi)
I have an Integra MC in the room next to me but I need to go back and get the booster for it before I can use it. And goddam work has me working 7 days a week I have no time.
Old Jul 9, 2003 | 05:00 PM
Anyone else?
Old Jul 9, 2003 | 05:45 PM
Atomic 1320's Avatar
Your brake check valve holds vaccume for the vaccume assist when there is no vaccume from the motor. Kinda like a reserve that can be used 1 or 2 times. Thats all it dose. It should not make the petal soft.
You probably have a bad seal. When you pump the brakes up and keep pressuse on it dose it sink back to the floor? If it dose then you have a bad seal in your MS
Old Jul 9, 2003 | 05:51 PM
Default Re: Bad Brake Booster Check Valve? (Atomic 1320)
Yeah. Well whatever I will slap in a Teg MC and Booster soon enough.
tunerkid7
12
Dec 1, 2010 10:46 AM
djnikko
Feb 6, 2010 10:43 AM
crazyboy
10
Sep 15, 2009 08:04 PM
85mm LS VTEC
Mar 31, 2007 07:57 PM
RE- v8killa121
Jul 20, 2006 02:52 PM
