type r lost motion assembly
Old Jul 9, 2003 | 11:00 AM
jspec21's Avatar
Default type r lost motion assembly
I've searched this topic and haven't found what I've been looking for. I have a b16 head and what to upgrade my cams but I heard that one needs the type r LMA to prevent cams from breaking. So if anyone is selling or knows of a good site that I can find a well priced type r LMA, I'd appreciate it. thanx
Old Jul 9, 2003 | 11:40 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: type r lost motion assembly (jspec21)
Not worth it IMHO.
Old Jul 9, 2003 | 12:25 PM
MaxBoost's Avatar
New User
Default Re: type r lost motion assembly (Mr Milano)
You definately need them if your running big big cams..
As far as I know, newer b16 and gsr heads already come with them. they are the same as ITR LMA's, the only ones that are not good enough for the big cams are from older heads, I think from 96+ gsr heads have them ready to go..
But you only need them for really big cams.. I know for a fact you can run Jun III's AND Toda C's w/ a first gen b16 head with no problems. but anything bigger then those, definately upgrade.
Old Jul 9, 2003 | 12:32 PM
Irishweird00's Avatar
Banned
Default Re: type r lost motion assembly (MaxBoost)
The GSR and B16 heads have their own Lost motion ***. The type R's have different ones, diff part numbers
Old Jul 9, 2003 | 01:20 PM
Twenty36_1's Avatar
Default Re: type r lost motion assembly (Irishweird00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">The GSR and B16 heads have their own Lost motion ***. The type R's have different ones, diff part numbers</TD></TR></TABLE>
Yup, I called acura myself and had them run the part numbers. GSR's are the same as B16 (P30 part number) and ITR has their own (P73). If you don't believe us call for yourself. Now whether they are needed or not I am unsure. Hope that helps.
Old Jul 9, 2003 | 01:29 PM
b19coupe's Avatar
I am sending Rocket a GSR and a Type-R lost motion assembly for testing. Hopefully he will post results next week. Compressing them by hand, the Type-R LMA "seems" stiffer, but we will see.
Old Jul 9, 2003 | 01:39 PM
Twenty36_1's Avatar
Default Re: type r lost motion assembly (b19coupe)
let us know what the results are. The stiffness is the only reason I figure that they have different part numbers.
Old Jul 9, 2003 | 01:58 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">I am sending Rocket a GSR and a Type-R lost motion assembly for testing. Hopefully he will post results next week. Compressing them by hand, the Type-R LMA "seems" stiffer, but we will see.</TD></TR></TABLE>
I'll have pics and do some measurements with calipers and put those things on a spring tester.
Stay tuned.
Thanks B19coupe for the help.
Old Jul 9, 2003 | 02:00 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Not worth it IMHO.</TD></TR></TABLE>
umm... u care to explain a lil more about what you mean?
Old Jul 9, 2003 | 04:12 PM
MAX_CFM's Avatar
We modify The GSR and Late model b16 LMA's in house
for a small fee
Old Jul 9, 2003 | 04:20 PM
Rocket's Avatar
Default Re: type r lost motion assembly (MAX_CFM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">We modify The GSR and Late model b16 LMA's in house
for a small fee</TD></TR></TABLE>
Nice . We are also working on some modded units oursleves.
Old Jul 9, 2003 | 06:03 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: type r lost motion assembly (Bob-DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">
umm... u care to explain a lil more about what you mean?</TD></TR></TABLE>
How much more clearer can I be. We have done plenty of JUN III/TODA C type set-up's with stock B16 or GSR LMA's with no problems what so ever with proper valvetrain. So untill I see a reason fit....
Old Jul 9, 2003 | 06:13 PM
Banned
I'm still confused as to how people would think you would need to swap in a ITR lost motion, I mean both motors rev just as high as eachother, if you swap in springs/valves/retainers/cams.... whats the problem as long as you replace or upgrade what you need to upgrade....
Old Jul 9, 2003 | 06:36 PM
Mr Hammond's Avatar
a/k/a Jomo
Well the whole theory behind it is because ITR's have more aggressive cams. Hence why their valvetrain is upgraded over a B16 or GSR motor as well, but was I said before.....
Old Jul 9, 2003 | 07:34 PM
b19coupe's Avatar
There is a post by Earl about LMA's binding and causing cam breakage Here
That is one thread I know of that goes into depth about the LMA issue.
Old Jul 10, 2003 | 10:57 AM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">There is a post by Earl about LMA's binding and causing cam breakage Here
That is one thread I know of that goes into depth about the LMA issue.</TD></TR></TABLE>
I remember reading about this and had good points.
Thanks for getting the link for me since i'm worthless on the search ffunction.
-Bert
Old Jul 10, 2003 | 03:27 PM
Banned
Default Re: type r lost motion assembly (BERT-O)
so, where can you get ahold of a lost motion for ITR's....?? Or how much should i say
Old Jul 10, 2003 | 04:01 PM
Spids5's Avatar
Don't judge or question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Irishweird00 &raquo;</TD></TR><TR><TD CLASS="quote">so, where can you get ahold of a lost motion for ITR's....?? Or how much should i say</TD></TR></TABLE>
I would try ebay. Once and a while there are some on there for sale, I got mine for $135. Or you could go to acura but they wanted over $200 and I have a hook up.
lopezchris21
Aug 24, 2008 11:46 PM
bballchris24
Apr 3, 2008 05:56 AM
ej1252
15
Oct 25, 2007 04:26 AM
JDM93EG
Nov 22, 2004 12:27 AM
