how to read camber?
There are several types of guages on the market, the best ones for race use cost in the hundreds of dollars. However none of them are as accurate as an actual alignment machine.
If you're wanting to try to adjust a camber kit yourself, don't. When the car's ride height changes, toe-in also changes, and depending on the type of camber kit you have, it could also possibly affect toe, which has the most impact on tire wear. Get it adjusted on an alignment machine if you want the most life out of your tires.
E36 Guy
16
Apr 7, 2006 09:58 AM
