Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
hpde tires
Old Jul 9, 2003 | 09:59 AM
sykikchimp's Avatar
Default hpde tires
would you guys rather have 225/45/17 azenis all around, or 205/45/16 Kumho V700's?
do you guys think a 225 series victoracer would work on a 16x6.5 wheel?
Charles - who thinks he's making things harder than they need to be..
Old Jul 9, 2003 | 10:02 AM
XR4racer's Avatar
Default Re: hpde tires (sykikchimp)
for hpde's, the Later... but the first choice would last longer, if you have the camber to support the 225s
Personally I think the 225s would be too wide for a 6.5 in wheel.
Old Jul 9, 2003 | 10:12 AM
sykikchimp's Avatar
Default Re: hpde tires (XR4racer)
I can run as much camber as I need. suspension is fully adjustable. How much camber would I need for the 205 v700's?
Maybe I should just sell these wheels, and get something a bit wider for the track...
Old Jul 9, 2003 | 10:19 AM
Crack Monkey's Avatar
Does your car have safety gear? Remeber that with R-compounds, your speed increases quite a bit.
Also, the Azenis will last a lot longer and be more forgiving than the R compounds when you screw up.
Old Jul 9, 2003 | 10:33 AM
XR4racer's Avatar
I run 15x7" wheels w/ 205/50/15 size tires. These work well. I like the 15" wheels because it helps with initial acceleration exiting a turn(lower ratio). The 205 works well with my camber settings(-1.8 total up front), and gives a nice side profile on a 7" rim. I tried 225s to see what all the hype was about... tore them up. My deduction is that I would need more negative camber (about -2.5 total) to run these efficiently, and a wider(7.5") wheel would probably help, but 7" is as wide as I can go in my series.
Key points to remember... for all cars, since you have a different car than me:
1) Smaller diameter (15") would have less weight, and emulate lower gearing than a larger(17") wheel.
2) wider may give a bigger footprint, but if your wheel width and camber isn't set to support that width, it can have negative effects on handling and tire wear.
Old Jul 9, 2003 | 10:34 AM
Mike P.'s Avatar
25 Year Member
I think a nice 215/45-16 Azenis would work well on those 16" wheels. That's what I would use without the appropriate safety gear. Or Azenis on the "17s."
Mike
Old Jul 9, 2003 | 10:36 AM
sykikchimp's Avatar
Default Re: hpde tires (Crack Monkey)
you bring up a good point.. I "plan" to get the roll bar, seats, and harness within 6 months or so. So I'll probably end up doing 2-3 events before the safety gear goes in. I already upgraded my brakes to 4-pot 300zx calipers, and good fluid, etc, so I know I can stop..
I'll be runnin in Intermediate if that makes a difference.
Old Jul 9, 2003 | 10:41 AM
BryanSprinkel's Avatar
Default Re: hpde tires (Mike P.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike P. &raquo;</TD></TR><TR><TD CLASS="quote">I think a nice 215/45-16 Azenis would work well on those 16" wheels. </TD></TR></TABLE>
I would have to agree with Mike. We used the 215/45-16 Azenis on George's ITR for over a year, and they work great for schools, and provide lots of grip for the money. That would be my vote.
Old Jul 9, 2003 | 10:42 AM
Mike P.'s Avatar
25 Year Member
Where are you going to be, Charles? VIR with CarGuys?
Old Jul 9, 2003 | 10:52 AM
sykikchimp's Avatar
I wish.. :drool: Going to Atlanta Motor Speedway for the 240sx national convention, then proabably Shenandoah with Nasa at the beginning of Sept, and then Roebeling with Thscc near the end of sept.
Old Jul 9, 2003 | 11:05 AM
AKADriver's Avatar
At least for me, running the 215/45-16 would get annoying... the effective gearing change would force a lot more shifts between 3rd and 4th than I do now. But, I don't know how much faster you are with Intermediate skillz and suspension work.
If it matters, I haven't even seriously considered stickies for my car.
Old Jul 9, 2003 | 12:23 PM
sykikchimp's Avatar
Default Re: hpde tires (AKADriver)
I think I could really use a smaller tire.. I've only been on VIR N, Full, and lowes, but at all three I had corners where I ended up too high in the revs to downshift, but too low to give me the power I need to really pull through the corner..
I'm sure I may find myself in the exact opposite situation though as I don't notice when the revs are perfect for a corner..
Only reason I'm really considering the sticky's is because it was suggested by my last instructor that I could really benefit from running some victoracers or equivelent.. that and getting rid of my stupid fuel cut at 115.
Old Jul 9, 2003 | 12:28 PM
mityVR6's Avatar
FWIW, I know several folks who have used 225-50-16 Victos on 16x6.5 VW wheels with good results. Same overall size (well, almost... it's pretty exact with street tires) as the 225-45-17.
-Adam
Old Jul 9, 2003 | 03:50 PM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykikchimp &raquo;</TD></TR><TR><TD CLASS="quote"> then proabably Shenandoah with Nasa at the beginning of Sept</TD></TR></TABLE>
I don't think it will be open. Last time I heard it was still dirt.
I would also go with these 215/45-16 Azenis
Old Jul 9, 2003 | 06:48 PM
sykikchimp's Avatar
Default Re: hpde tires (FURBALL B-16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FURBALL B-16 &raquo;</TD></TR><TR><TD CLASS="quote">
I would also go with these 215/45-16 Azenis </TD></TR></TABLE>
Well isn't that just sh1tty... arr..
Old Jul 10, 2003 | 04:13 AM
thecaptain's Avatar
Run the street tires. They are better for HPDEs as they will give you audible feedback. Plus, if you make a mistake you haven't trashed a race tire!
I have done class room for several years and I ALWAYS suggest street tires for schools. Race tires do not make you any better (sometimes they make you worse as they cover mistakes) they just make you faster.
Have fun!
Old Jul 10, 2003 | 06:19 AM
JoelG's Avatar
Default Re: hpde tires (thecaptain)
if it was up to me there would be no R compound tires allowed in the beginner or intermediate groups and you'd be required to have a harness and roll bar to use them in the advanced group.
Like the captain said, you will learn better on street tires. More feedback, larger slip angles and lower speeds make for a much better learning environment. I would suggest using something at least V rated though. My experience with H rated tires is they really dont hold up under track conditions -- they chunk badly.
as far as the size goes, 16" tires generally cost less than 17". saving money
joel
Old Jul 10, 2003 | 06:44 AM
clm's Avatar
clm
Default Re: hpde tires (JoelG)
From those two choices, I would go with the Falkens - but then again those are the only tires I've only tried. Besides, they're cheap.
Honestly, though, I had a blast on all-seasons at Mid-Ohio. They didn't stick as well, but with a lower HP car, the less traction helped me slide more and feel faster.
Old Jul 10, 2003 | 07:02 AM
sykikchimp's Avatar
Thanks for the opinions guys!
Falkens will be comming on payday.. I sure hope the 16"ers aren't on national backorder.
shahriar35
Dec 16, 2014 08:07 AM
Low and no vtec
Aug 29, 2013 07:12 PM
evosix
May 25, 2009 12:30 PM
evosix
Suspension & Brakes
May 22, 2009 06:42 AM
D C 2
May 17, 2009 01:34 PM
