Swapping 97 LS motor into 93-95 Si Hatch
Old Jul 9, 2003 | 09:56 AM
ShowtimesDC2's Avatar
Default Swapping 97 LS motor into 93-95 Si Hatch
Just about to swap a complete 97 Integra LS motor into a 93-95 Si hatch. Was wondering if there is anything that I have overlooked or things that you guys know that would help me complete this swap as clean and easy as possible. I have EVERYTHING from the integra because it was a rear-end total. Would like to keep power steering and A/C. Any help would be greatly appreciated. I have done a few swaps before, but I haven't done this one. Thanx.
Old Jul 9, 2003 | 10:13 AM
allmtr's Avatar
Default Re: Swapping 97 LS motor into 93-95 Si Hatch (SILSRocket)
if u have the whole integra front, then u have everything. you migh wanna use a jumper harness for obd1
Old Jul 9, 2003 | 10:21 AM
viet's Avatar
Default Re: Swapping 97 LS motor into 93-95 Si Hatch (allmtr)
direct swap.
Old Jul 9, 2003 | 10:38 AM
acuracing's Avatar
I noticed you're in CA. Do you plan on running everything OBDII, because you may run into problems if you get pulled over and you don't have a BAR sticker for the swap.
RICEBURNER1406
Jan 14, 2003 04:29 PM
gunmetalR
May 20, 2002 01:54 PM
