quick question on brakes...
Old Jul 9, 2003 | 08:36 AM
98cwtypeR's Avatar
Default quick question on brakes...
k, my brakes are worn out and need replacing, the only thing I need to know is...do I just need to replace the pads or do I have to replace the whole disk brake? Also, I just want to make sure that the ITR has disk brakes all around correct?
Old Jul 9, 2003 | 08:39 AM
Dave-ROR's Avatar
Default Re: quick question on brakes... (98cwtypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwtypeR &raquo;</TD></TR><TR><TD CLASS="quote">k, my brakes are worn out and need replacing, the only thing I need to know is...do I just need to replace the pads or do I have to replace the whole disk brake? Also, I just want to make sure that the ITR has disk brakes all around correct?</TD></TR></TABLE>
Yes, the ITR has discs all around. We can't really say what needs to be replaced without seeing it, but you can get front rotors for $25 each from autozone. Use OEM or better pads (OEM is fine for the street). You'll need to check the pads to see if all of them are worn, or just the fronts, just the rears, etc.
Old Jul 9, 2003 | 09:24 AM
STOLEN - ITR 98-0652's Avatar
Based on your familiarity and inferring that to your maintenance history...
Flush the fluid, too.
Old Jul 9, 2003 | 10:28 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwtypeR &raquo;</TD></TR><TR><TD CLASS="quote">k, my brakes are worn out and need replacing, the only thing I need to know is...do I just need to replace the pads or do I have to replace the whole disk brake?</TD></TR></TABLE>
You only have to replace the pads.
There are various reasons to replace the rotors - if they are warped (so that there is a vibration when you use the brakes, even when they're cold) or if you have been using them a while and they become thinner than the minimum spec. Unless something like that is going on, just leave 'em.
Old Jul 9, 2003 | 10:43 AM
98cwtypeR's Avatar
Default Re: quick question on brakes... (nsxtasy)
yea thats what i figured, but the place where I got my inspection at said they don't do just brake pads. They do the whole disk brake due to liability. So I'm just going to do the job myself, just need those answers so I could get the parts.
thanks for the info.
Kendo88
Mar 10, 2009 09:57 PM
GuCCi_GSR
Jan 30, 2008 10:25 AM
hatchinprogress
Aug 31, 2006 10:01 PM
.M.
Mar 23, 2004 08:28 PM
mikeSONICGSR
Dec 10, 2001 03:12 PM
