ITR 5 lug conversion 93 civic si - what MC/brake booster, prop. valve, and brake lines?
Old Jul 9, 2003 | 07:33 AM
midnightdarknes5's Avatar
Default ITR 5 lug conversion 93 civic si - what MC/brake booster, prop. valve, and brake lines?
sup fellas I'm doing a ITR 5 lug conversion to my 93 civic si soon. was wondering what MC/brake booster, prop. valve and brake lines should I use. I was told I can retain the existing stuff from my civic but was figuring upgrading to the sufficient parts to match the brakes and what not would be better. let me know what yall think.
Old Jul 9, 2003 | 11:34 PM
bump...
Old Jul 9, 2003 | 11:40 PM
Status Sean's Avatar
Default Re: ITR 5 lug conversion 93 civic si - what MC/brake booster, prop. valve, and brake lines? (midnigh
when i did mine i used the R brake booster and aftermaket lines seem to work for me
Old Jul 10, 2003 | 05:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rw92civic &raquo;</TD></TR><TR><TD CLASS="quote">when i did mine i used the R brake booster and aftermaket lines seem to work for me </TD></TR></TABLE>
thanks for the response. I think I might just end up using a Integra RS 4040prop. valve, 15/16 MC/brake booster being that it needs no modifications. and it's only 1/16th of a inch smaller than a 1"typer MC. any other suggestions?
Old Jul 10, 2003 | 05:42 PM
Blue-Civic-Hybrid's Avatar
Loved
When I did my 5-lug conversion myself, I used a 1' GSR MC from a 94-95 Integra, 4040 prop valve from a 93 Si hatchback, and ITR Russel SS brake lines..everything bolted in and it works great....
Good luck on the install...
Old Jul 12, 2003 | 11:42 PM
bump...
Old May 17, 2004 | 04:16 PM
SMZ GSR's Avatar
Default Re: (midnightdarknes5)
Back from the dead
What about on a 95 CX hatch? We just picked up the 5lug swap and will be getting an ITR master cylinder tomorrow, and we're looking for an ITR booster, so which prop valve is best?
I've been told Integra RS would be good since the RS lacked ABS like the CX but what difference does that really make? (5lug n00b )
Thanks.
Old May 18, 2004 | 09:13 AM
Dang EG's Avatar
Default Re: (SMZ GSR)
^^^ looking for same answer
Old May 18, 2004 | 09:22 AM
ki3t's Avatar
This user can set his title.
Default Re: (Dang EG)
For my 5 lug conversion on my 93 coupe I used the following:
1. JDM ITR Brake booster
2. JDM ITR Master Cylnder
3. 40/30 - 93 Civic SI proportioning valve (soon to upgrade to 40/40)
4. Goodridge steel braided brake lines.
So far it's been great. Any more questions just PM me.
Old May 18, 2004 | 07:28 PM
makibaka's Avatar
Default Re: (Ki3t)
Supposedly the 30/40 prop valve (I forget which car it's from) is best as told to me by a local racer. The 40/40 prop valve is too rear biased for our lightweight chassis (compared to the DC2 body) and will lock up the rear brakes before the front ones under hard braking. I don't have first hand experience with this though until after I install my 5 lug on my EH2. I have both a 40/40 and a 30/40 prop vavle and will post my results...
Old May 18, 2004 | 07:33 PM
Loved
Default Re: (makibaka)
As I stated in my previous thread, the 40/40 prop valve will not lock up the rears first..how do I know? I have been testing it for over the course of 4 years, the 40/40 prop valve works perfectly for the ITR brake bias.....
Old May 18, 2004 | 08:17 PM
Jim_Dandy's Avatar
Default Re: (Blue-Civic-Hybrid)
I used a 15/16 M/C and 40/40 prop valve with my JDM 4 x 114 conversion.
The front line on the M/C will have to be bent a little bit to fit properly. It will be a very tight fit.
Make sure to use all new brake fluid. Which one you choose is up to you depending on what the purpose of the car will be, i.e. street/auto-x/drag/lapping
Also be very careful when threading in the fitting to avoid cross threading. The metal is very soft and will strip faster then you can imagine.
If you want you car to stop like a 4 wheel disc is supposed to, source out all the parts. Braided lines are an added bonus if you have the money, but not 100% necessary.
If you do happen to have a bit of extra cash, invest in some Russel speed bleeders. It will make bleeding the brakes a one person job, and make it a lot faster. They come in packs of 2, the one you would be looking for is "639610" . It 10mm with a 1.25 thread pitch
HTH
Old May 18, 2004 | 09:39 PM
cxSHOE's Avatar
Default Re: (Artificially_Aspirated)
i would disagree with the speedbleeders. if you want a great one man brake job get a powerbleeders pressure system... about 40 bucks.. you will find that its hard to gauge the speedbleeders and most if not all tighten them too tight and break them which is more pain that you do not need.
just my 2 cents
i also have a 1" gsr m/c and booster in my sig if interested.
Old May 19, 2004 | 11:38 AM
Jim_Dandy's Avatar
Default Re: (cxSHOE)
i have had my Russel bleeders on for about 2.5 yrs without any problems what so ever. If you know what you are doing when you bleed the brakes, you will not break the bleeders off
Old May 31, 2004 | 07:13 PM
CHiNkStEr's Avatar
im getting ready to do a 5-lug conversion on my 92 si hatch too. is the type r brake booster and the si brake booster the same? let me know asap.
Old May 31, 2004 | 07:53 PM
wizzards581's Avatar
Default Re: (*****StEr)
im rollin on mines..
itr 5lug on EG si... civic everything... no problem for me.
soon to get RS mc,bb.
Old May 31, 2004 | 07:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
i still have my stock prop and m/c, with goodrige steel lines. stops on a dime.
Old Jun 9, 2004 | 01:11 AM
CTRbOy's Avatar
we have 3 5lug civics at our household. 2 SI's hatch and coupe and one DX hatch
we used integra gsr BB, MC . 91 integra PV. 4040!!! not 4030...4040 is what you need. after 3 5lug conversion i think we know what we need for 5lug.
the red hatch SI is for sale
all vehicales are b18c5 powered with ITR interior
asking $8k for the red hatch SI. PM for more info.
Old Jun 9, 2004 | 02:48 AM
Dori-U's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrboy &raquo;</TD></TR><TR><TD CLASS="quote">we have 3 5lug civics at our household.
Wish I had an ITR parts tree growing in my backyard... or maybe not.
Old Jun 9, 2004 | 04:31 AM
CTRbOy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dori-U &raquo;</TD></TR><TR><TD CLASS="quote">
Wish I had an ITR parts tree growing in my backyard... or maybe not. </TD></TR></TABLE>
paperwork for motor comes with the purchase of the 94 b18c5 powred SI.
Old Jun 9, 2004 | 04:44 AM
Built to Spill's Avatar
el diablo
When i did my swap i just used the ITR MC. I used my stock BB and prop valve and lines. I drove a local R (stock) and mine seems to stop equally as nice as his.
Old Jun 11, 2004 | 07:31 AM
Jon V's Avatar
I'm getting the ITR MC PROP and BOOSTER but I am thinking of installing the 5 lug befor I get them.
https://honda-tech.com/zerothread?id=891751
Old Jun 15, 2004 | 03:40 PM
CHiNkStEr's Avatar
if you don't change the brake booster and the other **** that holds the liquid it brakes like ****...i know because mine is breaking like **** right now. i have to press the brake pedal almost all the way to the floor before it brakes. lemme know whats wrong someone.
Old Jun 15, 2004 | 03:50 PM
92slowvic's Avatar
how can you tell the difference from a 30/40 prop and a 40/40 prop say they were side by side? i have a prop that im looking to sell outta my 1992 5 lug hatch but not sure what it is? thanx
Old Jun 15, 2004 | 04:16 PM
makibaka's Avatar
Default Re: (92slowvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92slowvic &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell the difference from a 30/40 prop and a 40/40 prop say they were side by side? i have a prop that im looking to sell outta my 1992 5 lug hatch but not sure what it is? thanx</TD></TR></TABLE>
It will be stamped/"engraved" on the side of the prop valve. It may be hard to miss if the part is a little dirty...
