How to change axles?
Old Jul 9, 2003 | 07:17 AM
Accord_Kid's Avatar
Default How to change axles?
would anybody happen to have the instructions on how to change the front axles on a 96 accord LX?
Old Jul 9, 2003 | 09:12 AM
roydogg's Avatar
Default Re: How to change axles? (Accord_Kid)
Try the tech forum you'll get a better response .
Old Jul 9, 2003 | 08:37 PM
TypeSH's Avatar
Default Re: How to change axles? (roydogg)
I know how to pop the driver side off, the passenger side is prob the same. Not sure about the intermediate shaft thou.
On the driver side:
unstake the axle nut
loosen the axle nut (like breaker bar + pipe or an air/impact gun)
jackup car, set on stands and remove the wheels and axle nut
Undo the bolts holding the brake lines to the struts
Remove the 2 bold holding the caliper on and hang it from the upper control arm or set it down somewhere on a block. Don't let it hang by the brake line.
Pop all of the ball joints (tie rod, upper and lower) loose
Somehow move the knuckle around and tap the axle end w/ a mallet til you seperate the axle from the hub
after you get the knuckle/hub off the axle, get a flat screwdriver and pry at the point where the half-shaft is inserted into the middle section. Sorry, no pictures. =\
That should pop it out. Pop in a new axle and reinstall is the reverse.
Old Jul 10, 2003 | 04:15 PM
Accord_Kid's Avatar
Default Re: How to change axles? (TypeSH)
kool thanx man
Old Jul 10, 2003 | 07:04 PM
IN VTEC's Avatar
Unless it's a special case with the Accord's, you shouldn't need to remove the brake calipers to pop the axles outta the hubs. Just undo the brake line brackets if you need more slack to rotate the knuckle out.
Old Jul 11, 2003 | 12:10 AM
TypeSH's Avatar
Default Re: How to change axles? (IN VTEC)
yea, now that i think about it, you might not have to. I was replacing my bearings at the time so the calipers had to come off to pull the rotors off.
but the whole unit will be freakin heavy w/ everything attached to move it around out of hte way. like 40-50 lbs for the knuckle/hub/rotor/bearing/caliper. =P
Old Jul 24, 2003 | 09:48 AM
Accord_Kid's Avatar
bump.....anybody has any objections or suggestions before i get started?
Old Jul 24, 2003 | 01:40 PM
TypeSH's Avatar
if you remove the brake line off the caliper, you must bleed your brakes after. if you didnt, you probably dont have to.
Old Jul 25, 2003 | 03:50 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">if you remove the brake line off the caliper, you must bleed your brakes after. if you didnt, you probably dont have to.</TD></TR></TABLE>
Yeah, but I've always been able to tie the calipers up somewhere so I don't disconnect the lines.
Be careful NOT to let the calipers hang by their own hoses. That'll probably damage the hoses, they'll be weaker & maybe burst someday...
Old Jul 25, 2003 | 01:03 PM
ClownShoes's Avatar
yea, then you'll need a pair of clown shoes
ClownShoes's Avatar
Default Re: (ClownShoes)
clown
sanman000719
Jul 7, 2011 07:47 PM
ugandaHonda97
Dec 15, 2010 12:59 PM
sony224422
Jul 7, 2007 03:29 PM
Rocks
Jun 27, 2004 04:23 PM
johnzm
Aug 30, 2002 09:56 PM
