Calling all owners with Legend rotor and NSX caliper
Old Jul 8, 2003 | 09:51 PM
JustLooking's Avatar
Default Calling all owners with Legend rotor and NSX caliper
I'm currently running NSX calipers on stock R rotors. I got my Legend rotors today from a GS coupe and tried installing the rotor but ran into a problem. The huge Legend rotor rubs on the caliper bracket. Looks like the stock R bracket is a very tight fit for the Legend rotor. Do I have to change the caliper bracket to the Legend one? Please help.
Old Jul 8, 2003 | 11:02 PM
Dr Pooface's Avatar
Default Re: Calling all owners with Legend rotor and NSX caliper (JustLooking)
I believe a spacer for the caliper bracket is needed.
Edit:
Quoting Migs from this thread: https://honda-tech.com/zerothread?id=239844
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">2) Using NSX calipers + GS rotors requires you to "shim" the caliper bracket out a littie bit. This can be accomplished by using washers. I had only used 1 washer per bolt.</TD></TR></TABLE>
Modified by Dr Pooface at 6:27 AM 7/9/2003
Old Jul 9, 2003 | 08:38 AM
Looose_R's Avatar
you must run a washer on each bolt of the bracket. if your still confused, ill jack up the car and take a pic for you
Old Jul 9, 2003 | 09:01 AM
jonsteR's Avatar
Default Re: Calling all owners with Legend rotor and NSX caliper (b20bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20bastard &raquo;</TD></TR><TR><TD CLASS="quote">you must run a washer on each bolt of the bracket. if your still confused, ill jack up the car and take a pic for you</TD></TR></TABLE>
I'd like to see the pics if you get around to it. Thanks.
Onyxeros
Suspension & Brakes
10
Jun 24, 2014 02:47 PM
John M
Apr 5, 2014 05:02 PM
I like my R
Jan 22, 2013 07:21 PM
93dabeast
Feb 9, 2006 12:45 PM
dayaftertomorrow
Acura TL, RL & ZDX
11
May 29, 2005 10:15 PM
