jun3 + stock timing belt
Old Jul 8, 2003 | 08:54 PM
b18prl's Avatar
Default jun3 + stock timing belt
has anyone experienced broken stock timing belt with jun3?
Old Jul 8, 2003 | 08:58 PM
aLLjDMRalf's Avatar
Default Re: jun3 + stock timing belt (b18prl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18prl &raquo;</TD></TR><TR><TD CLASS="quote">has anyone experienced broken stock timing belt with jun3?</TD></TR></TABLE>
me too i wanna know if its nessesary to buy a a/m belt
Old Jul 8, 2003 | 09:07 PM
b18prl's Avatar
Default Re: jun3 + stock timing belt (SlOwCrXbUtUbNbEaT)
How high were you reving it up to? my broke @3000 rpm
Old Jul 8, 2003 | 09:08 PM
projecthybrid04's Avatar
i'd like to know also, not that im gettin jun stage 3s i just wanna build up my knowlege of na tuning
b18prl's Avatar
What kind of power you're making coz i have a c5 too
Old Jul 8, 2003 | 09:10 PM
b18prl's Avatar
mann i was cruising down the road shifting into third gear around 3k and it just broke
Old Jul 8, 2003 | 10:00 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18prl &raquo;</TD></TR><TR><TD CLASS="quote">mann i was cruising down the road shifting into third gear around 3k and it just broke</TD></TR></TABLE>
How many miles were on it? Was the install done correctly?? as far as the tension on the belt.. And what kinda gears were u using?
Old Jul 8, 2003 | 10:07 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: jun3 + stock timing belt (ArinX)
I think a factory fresh Timing Belt will be fine.
Old Jul 8, 2003 | 11:00 PM
-Racer X-
Guest
Posts: n/a
Default Re: jun3 + stock timing belt (Mr Milano)
think? :/
Old Jul 8, 2003 | 11:09 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: jun3 + stock timing belt (-Racer X-)
Oh for the love of.... You <U>WILL</U> be just fine.
Old Jul 9, 2003 | 04:28 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">Oh for the love of.... You <U>WILL</U> be just fine.</TD></TR></TABLE>
ditto but if your that worried just spend $150 on a PE or get a Toda belt
peace of mind that your car is reliable if priceless
Old Jul 9, 2003 | 06:34 AM
b18prl's Avatar
i run c5 block c1 head stock head gasket juns cam gears jun spring skunks retainers cam gears were at zeros jun 3 degreeed in @ 110 degrees on primary lobes for both cams.
Old Jul 9, 2003 | 06:37 AM
advanracing62's Avatar
I would never run a high lift cam with a stock belt... They don't cost that much and it's better to have overkill than be killed.
Old Jul 9, 2003 | 06:40 AM
B16GSR's Avatar
Default Re: jun3 + stock timing belt (advanracing62)
i agree, pick up a pe belt for confidence in the motor
Old Jul 9, 2003 | 07:38 AM
BERT-O's Avatar
I have put 2,000 miles on a stock t-belt with Jun3's but I havn't really redline yet since I already kill the piston rings , this is what you get when you don't tune it .
Stock belts are known to break at any given time.
Leo at JDMspecperformance sells the strong belts. Which I waiting on to call him in a bit.
Tell me, whats cheaper.....a $160 belt or a new head and block $3500
-Bert
Briang3a3
Jan 11, 2008 07:10 PM
m_cough
May 22, 2007 07:50 PM
ITSUKA
Oct 2, 2005 05:01 PM
kobeRy_si
Jun 30, 2005 06:36 AM
vietnogi
Apr 18, 2005 11:26 AM
