rpm's drop when clutch is pressed
Old Jul 8, 2003 | 07:16 PM
VTgringo's Avatar
Default rpm's drop when clutch is pressed
I have a 89 crx with a zc and an si tranny. I am having this problem only when my clutch is pressed. do i need more slack on my clutch cable? I am also getting a code 9 on my ecu. I know i need a new distributor and it idles really bad. My question is will my distributor change fix the problem with the rpm's dropping with clutch engaugement.
Old Jul 8, 2003 | 08:30 PM
91civicEX's Avatar
check your wiring. the cyl sensor wires could be turned around. on the ZC they are on the other side of the cam from the dist.
Old Jul 9, 2003 | 12:04 AM
andertom's Avatar
Default Re: (91civicLX)
Hey,
I have the same clutch problem on my '91, only it works fine most of the time.
Old Jul 9, 2003 | 04:36 AM
VTgringo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">check your wiring. the cyl sensor wires could be turned around. on the ZC they are on the other side of the cam from the dist.</TD></TR></TABLE>
wires are fine. I tried swaping them one day and the car wouldn't even start.
bump for the morning guys
Old Jul 9, 2003 | 04:39 AM
FourthGenHatch's Avatar
Default Re: (VTgringo)
Uhhhh I've never driven a car where the rpms didn't drop down to idle speed when the clutch was pressed in.
Old Jul 9, 2003 | 05:04 AM
REDBARON's Avatar
Default Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Uhhhh I've never driven a car where the rpms didn't drop down to idle speed when the clutch was pressed in.</TD></TR></TABLE>
Me too. Maybe we're not understanding your question.
What exactly is your problem.
Old Jul 13, 2003 | 06:28 PM
andertom's Avatar
Default Re: rpm's drop when clutch is pressed (VTgringo)
Hello again,
I had the same problem, I recently added a short throw shifter and redline MT-90 synthetic manual transmission oil. The shifter came with new bearings and bushings which were shot on my stock shifter. Can't tell if it was one thing or a combo of both but it shifts great and it doesn't feel like my clutch is still engaged at a stop.
Modified by andertom at 10:02 PM 7/15/2003
QuarterMileMaster
Jul 24, 2007 12:51 PM
2000dollarzcbs
May 18, 2004 08:12 PM
EF_yo_89
Dec 24, 2003 03:28 PM
90crxzc
Apr 18, 2003 12:24 PM
