5 quarts enough to do an entire oil change?
Old Jul 8, 2003 | 06:45 PM
parasonic's Avatar
Default Topic change ;) About MTF now
I'm about to change my oil...from some cheapy conventional to Mobil 1 now that I 0wn the car. Should the 5 quart bottle be enough, or should I buy more while it's convenient? (i don't want to buy any more if I don't need it because I'm out of money )
I also got the oem filter..not some newspaper clipping fram loser brand! 73K miles..better to switch now than never!
Modified by parasonic at 12:50 AM 7/10/2003
Old Jul 8, 2003 | 06:47 PM
parasonic's Avatar
Default Re: 5 quarts enough to do an entire oil change? (parasonic)
Btw..D16Y8 (99EX stock)
built562's Avatar
4 qts is enough
Old Jul 8, 2003 | 07:17 PM
SuperMan19's Avatar
New User
Default Re: 5 quarts enough to do an entire oil change? (akumaracer)
what's wrong with fram filters? I use em all the time and they're cheaper priced too.
Old Jul 8, 2003 | 07:20 PM
EckoTech
Guest
Posts: n/a
Default Re: 5 quarts enough to do an entire oil change? (SuperMan19)
i use the PureOne...the better one of the two..works good for me..
oh yeah 4 quarts is enough..
Old Jul 8, 2003 | 07:32 PM
DSeriesBeeKilla's Avatar
3.4 quarts...i work at an oil and lube shop and i have the d16y8 too...it's 3.4 which includes the filter.....
Old Jul 8, 2003 | 07:46 PM
acuracing's Avatar
5 quarts is plenty enough.
Old Jul 8, 2003 | 07:51 PM
parasonic's Avatar
Default Re: 5 quarts enough to do an entire oil change? (acuracing)
Frell. I have to go to wal-mart now because it's the only thing open that has the metric wrench that im missing.
Old Jul 8, 2003 | 08:26 PM
BauleyCivic's Avatar
Risky Business
i used 3.75 qts on my 93 D15B7...and that put me 30% over full...
Old Jul 8, 2003 | 09:47 PM
Frozen E's Avatar
H-T White Ops
I thought it was 3.8 qts.
Oh well, anyway, 4 quarts should be enough unless you got some crazy *** oil pan under that thing (ie. moroso)
Old Jul 8, 2003 | 10:06 PM
parasonic's Avatar
Default Re: 5 quarts enough to do an entire oil change? (BauleyCivic)
Yea..3 quarts put me right at the middle. Growl! I can't find the funnel again, though..
Old Jul 9, 2003 | 08:15 PM
parasonic's Avatar
Okay..instead of starting a totally new thread, I'll just jack my own..it's related anyway.
How much MTF do I need to do a MTF refill? I have 74k miles and maybe could make the transmission a little happier if I help it out a little
Old Jul 9, 2003 | 08:22 PM
3 i think for the manual trans....but i'm not real sure...just put 10w30 in it.....it may take a little less than 3.....just fill it till it starts coming out of the fill hole....you'll need a 3/8" drive ratchet and a 17mm wrench....
Old Jul 9, 2003 | 08:47 PM
parasonic's Avatar
Default Re: 5 quarts enough to do an entire oil change? (99D16VTECCivic)
I bought a set of metrics last night for my 1/2 wrench (non ratchet :D)..17 did the oil..
But still..I've heard that there are minor disadvantages of 10w30.
Old Jul 9, 2003 | 08:51 PM
10w30 is what all the books at my work say for honda manual transmissions....and we haven't had any customers come back with messed up trannies....and also a former honda technician worked with me and that's what they put in them at his shop....
Old Jul 9, 2003 | 09:00 PM
Filliam H. Muffman's Avatar
5 is too much. dont use all 5 whatever you do.
4 is too much as it is..
Old Jul 9, 2003 | 09:05 PM
Risky Business
Default Re: 5 quarts enough to do an entire oil change? (JUN EK9)
2 qts of genuine honda MTF is all you'll need
Old Jul 9, 2003 | 09:06 PM
parasonic's Avatar
Heh..I already filled it last night. 3.5 quarts put me right at the top.
Motor oil, that is.
Old Jul 9, 2003 | 09:07 PM
PSU's Avatar
PSU
formerly DxHatchback
3.5 qts here
Old Jul 9, 2003 | 09:24 PM
Eee Pee's Avatar
Default Re: 5 quarts enough to do an entire oil change? (DxHatchback)
Ever read the OWNERS MANUAL?
It's all laid out in there...
And in response to the Fram oil filters...
Don't ever buy a Fram filter, ever. They have all kinds of problems.
From failing internally, to exploding. Just to sum it up.
Old Jul 9, 2003 | 09:28 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">2 qts of genuine honda MTF is all you'll need</TD></TR></TABLE>
please dont use MTR for motor oil
Old Jul 10, 2003 | 03:12 PM
stripes777's Avatar
i jus changed my mtf on my gsr tranny. i bought 3 bottles, u should use some to wash out the old one, i had extra left, for me, 2 wasnt enough, the tranyn took 2.3 i think.
the bolts were a bitch to take off, seemed like it was never changed before, i almsot gave up on it, then got mad and opened a can of whoop *** and got it off, haha, o ya the gasket for the fill plug is a fukn rip off, cost me 6 bucks at acura dealer, plus they gave me the wrong one, so i ended up using the old one, haha
Old Jul 10, 2003 | 03:24 PM
pdiggitydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parasonic &raquo;</TD></TR><TR><TD CLASS="quote">Yea..3 quarts put me right at the middle. Growl! I can't find the funnel again, though..</TD></TR></TABLE>
so you make a funnel out of a used oil bottle
I do it every time...I always save one bottle from the last time I changed it.
Old Jul 10, 2003 | 03:57 PM
shermanyang's Avatar
Default Re: (Frozen Si)
5 quarts if OVERKILL!!
Old Jul 10, 2003 | 04:10 PM
Default Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 &raquo;</TD></TR><TR><TD CLASS="quote">i jus changed my mtf on my gsr tranny. i bought 3 bottles, u should use some to wash out the old one, i had extra left, for me, 2 wasnt enough, the tranyn took 2.3 i think.
the bolts were a bitch to take off, seemed like it was never changed before, i almsot gave up on it, then got mad and opened a can of whoop *** and got it off, haha, o ya the gasket for the fill plug is a fukn rip off, cost me 6 bucks at acura dealer, plus they gave me the wrong one, so i ended up using the old one, haha</TD></TR></TABLE>
hey dude...what's your address i'll send you a free gasket....
