this is the second help of the day i feel like a loser
ok so i lowered my car right (suspension tech. springs) well one side i have -.63 the other side the passsanger side has -1.75 degrees why is this should they not be the same. i have driven 3000 miles on the springs and it has eaten the passanger side tire. yes i did get an allinment. any help would be greatly appreciated.
i figured that but y is one side worse than the other because i have no ******* money but it is a good investment
get a front camber kit for like 40-50 bucks and the rear can be corrected with spacers (washers) this will be a cheap and affective camber kit
what springs did you go with. if they are cheap springs then it could just be that the spring rates vary that much. that or you just mixed up a front spring and a rear spring.
hmmm...if anything I would've thought the problem would have been the opposite (driver's side having messed up camber).
bump
bump
STN_Pat
Jun 1, 2015 01:44 PM
originalg00kster
Suspension & Brakes
Sep 24, 2007 12:47 AM
